> Headlight wiring question - Solved, No voltage to one headlight
9**P-car
post Sep 30 2019, 08:54 AM
1975 2.0L
My driver's side headlight is not coming on. I checked voltage, and nothing is coming thru, low or high beam. The passenger side works great. Fog lights also work, turning off automatically when high beams are on.
I checked the headlight relay, and it is hooked up correctly. So my question is, does anyone know which terminals on the relay I should check for voltage in order to isolate the problem? Since the passenger headlight works, I'm thinking is a wiring problem leading to the driver's headlight.
Replies(1 - 6)
bdstone914
post Sep 30 2019, 08:59 AM
bdstone914
QUOTE(9**P-car @ Sep 30 2019, 07:54 AM) *
Start at the fuse box and check for voltage at fuses 1-4 that control the hi low left and right. Spin the fuses to make sure they make contact.
A wire diagram will be helpful.
9**P-car
post Sep 30 2019, 08:08 PM
1975 2.0L
Spinning the fuse was all it took. Brilliant response!! Thank you. That's what makes this such an awesome forum.
post Oct 1 2019, 12:19 AM
914-6 GT in waiting
But new fuses. They are cheap.
Tbrown4x4
post Oct 1 2019, 01:30 AM
And carry spares!
914Sixer
post Oct 1 2019, 07:11 AM
Clean all the terminals on the fuse block
post Oct 1 2019, 07:33 AM
914-6 GT in waiting
QUOTE(914Sixer @ Oct 1 2019, 09:11 AM) *
- Lo-Fi Version Time is now: 1st May 2026 - 04:20 AM
