4 Bolt Hub Hi Speed Brake Test, Sucessful from 135 to 35 at CA Speedway |
john rogers |
Jun 30 2005, 11:10 AM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Last weekend was the first chance to see how the hubs, M calipers and Pagid pads works from high speed. I found the pads do need to get warm some before they work well. I also found the M calipers on front had more "bite" than the BMW units and with the prop valve to the rear BMW calipers set with 25% reduction the front end would dive more. To cure this I set the new Koni Sport shocks at full stifness and that was cured. They worked great and it has turned out to be a great addition to the car. Thanks to the guys (fogot the names) that showed up to say hello, I hope everyone enjoyed the cars as we had a great mix in all classes.
brant |
Jun 30 2005, 11:28 AM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Mueller |
Jun 30 2005, 11:42 AM
cool...thanks for having the courage to "test" them like that...... (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
john rogers |
Jun 30 2005, 02:18 PM
The turn in for turn #3 has about 3/4 mile of run off if there was a problem and it does get used several times whenever we race there. I made sure no one was right in front or to the right so for the forst couple of times it was pretty safe. After that it was a non issue, compared to the car not wanting to turn left well???!!!
Lo-Fi Version | Time is now: 11th June 2024 - 04:40 AM |
