Billet Hub Studs, Need the original stud length for 5-lug billet hubs |
jim_hoyland |
Oct 17 2019, 06:42 PM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I bought the 5 lug Billet hubs from Brad back in the day. I’m seeking the stud length from someone that has installed or worked with them.
I’m going to add spacers and would like to order longer studs before pulling the hubs. Attached image(s) |
914Sixer |
Oct 17 2019, 07:15 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Thinking they were set up for stock 45mm hubs. Just add the thickness of the spacer you are going to use to the 45 mm.
mepstein |
Oct 17 2019, 07:28 PM
914-6 GT in waiting Group: Members Posts: 19,314 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Didn’t Mike Mueller design them?
@Mueller |
jim_hoyland |
Oct 17 2019, 07:53 PM
jim_hoyland |
Oct 17 2019, 07:54 PM
Tried Mike. Need someone who currently has them.... |
SirAndy |
Oct 17 2019, 07:55 PM
Resident German Group: Admin Posts: 41,678 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Just add up the thickness of the hub, the thickness of the spacer, the thickness of the wheel center mounting surfaces and add enough to get full thread engagement on the lug nuts you are going to use.
(IMG:style_emoticons/default/shades.gif) |
mepstein |
jcd914 |
Oct 17 2019, 09:20 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
The rule of thumb I was taught is, steel on steel you want thread engagement at least equal to the diameter of the stud and steel on aluminum you want 1.5 times the diameter of the stud.
So for a 14mmm stud you want a minimum of 21mm engagement into the aluminum hub and 14mm engagement into the lug nut if it is steel and 21mm of you have aluminum lug nuts. So 35mm or 42mm plus the thickness of the spacer you're going to use plus the thickness of the wheels you're using. I would include some additional length so I could have more thread engagement than minimum. What wheels are you running and what spacers are you going to use? Jim |
jim_hoyland |
Oct 18 2019, 05:09 AM
What wheels are you running and what spacers are you going to use? Jim Thanks: Wheels currently are Fuchs 16 x 6, spacers are 10mm Attached thumbnail(s) |
infraredcalvin |
Oct 18 2019, 09:33 PM
Distracted Member Group: Members Posts: 1,528 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
I’m not too far from you, met you once at my office in fashion island (I bought something off you, I forget what it was). I have a few sets of different lengths and a few different spacer widths. Your welcome to borrow and figure out what you need.
I’ll be working on my car next week Thurs and Fri, you’re welcome to come by the shop in Santa margarita and test it all there too... PM me if any of that works... Pat |
garrettlee2 |
Oct 18 2019, 09:38 PM
Member Group: Members Posts: 158 Joined: 8-September 12 From: riverside ca Member No.: 14,901 Region Association: None |
What's the deal with the 4 lug hubs? I have been looking for that exact thing. Are you coming to G and R if so could you bring one?
jim_hoyland |
Oct 19 2019, 05:06 AM
The 4 lug billet sets came and went years ago as well as the 5 lug sets, which I have on the car now. It was a great upgrade at the time; the SC vented rotors bolted up to the hubs and the wider 911M calipers could be installed. Very good for stopping !
jim_hoyland |
Oct 19 2019, 05:08 AM
Lo-Fi Version | Time is now: 8th June 2024 - 06:46 PM |
