Front Sway Bar fitting, Advice sought on fitting different front sway bars |
frostyf |
Nov 1 2019, 04:49 PM
Member Group: Members Posts: 153 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region |
Sorry finger trouble and duplicate post, can you del the second one please?
Hi, I'm looking at fitting a front sway bar on my 73 and need to ask fir a bit of advice. Ive spotted a few in tje classifieds tjat seem to go lile lightening. I've looked at a 22mm bar and wanted to ask if the through body bushing cups can be adapted (with a different size bushing) to take a stock 15mm bar or larger 22mm bars? I've been looking for bushing cups on eBay (90134375401 - https://www.ebay.com/itm/PORSCHE-911-912-91...4383.l4275.c10) Also are 911 front sway bars compatible with a 914 and or the same bushing cups? Thanks in advance! |
ConeDodger |
Nov 1 2019, 07:58 PM
Apex killer! Group: Members Posts: 23,612 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
It is a crime pretty much that some of the cars didn’t come with sway bars. The factory bars were easier to find when I bought mine, frankly, it was one of the most dramatic improvements I made.
Ultimately, I got a Taret bar and sold that stock one. They cost about double what the factory ones do these days but the quality is amazing. They are adjustable as well so you’re good for future mods as well. Just search Taret with Porsche and it should show up... |
Mark Henry |
Nov 2 2019, 08:08 AM
(IMG:style_emoticons/default/agree.gif) Almost the same story, my '74 1.8 (now a 3.0/6) came with no sway bars, first I added stock F/R sway bars and just this year I installed a Tarett 22mm adjustable hollow front sway bar.
Adding the stock bar was a 100% improvement and the Tarett almost doubled that figure. The Tarett bar comes with everything that's needed except the A arm bracket. I was lucky as my A-arm brackets were already on my arms but it's hit or miss, some no sway bar cars have the bracket and some don't. The bracket is available or easy to make, it has to be welded onto the arm. 911 used two styles of front sway bars, through the body bar and the under the body bar, you want the through the body style bar. |
infraredcalvin |
Nov 2 2019, 09:29 AM
Distracted Member Group: Members Posts: 1,528 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
I have stock front and rear bars and hardware I’ve been meaning to sell...
Mikey914 |
Nov 2 2019, 10:23 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I've made up a bunch of the A arm mounts for the drop links, so probably should get those listed up. I just needed to make paper templates to show where to mount.
iankarr |
Nov 2 2019, 06:41 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,481 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Sorry I can't speak to the questions in the OP, but there's a link to a swaybar install video in my signature. Hope it helps...
frostyf |
Nov 2 2019, 09:31 PM
Your video is really clear and easy to follow; thank you for taking the time to make and share it - its really helpful for a newbie like me.
maf914 |
Nov 3 2019, 05:17 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
(IMG:style_emoticons/default/agree.gif) Almost the same story, my '74 1.8 (now a 3.0/6) came with no sway bars, first I added stock F/R sway bars and just this year I installed a Tarett 22mm adjustable hollow front sway bar. Adding the stock bar was a 100% improvement and the Tarett almost doubled that figure. The Tarett bar comes with everything that's needed except the A arm bracket. I was lucky as my A-arm brackets were already on my arms but it's hit or miss, some no sway bar cars have the bracket and some don't. The bracket is available or easy to make, it has to be welded onto the arm. Yep, I agree. My 76 came without sway bars, but had the brackets on the front a-arms. I added H&H front and rear bars and Koni Red shocks. Major handling improvement. (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 01:16 PM |
