ticking turned to knocking (VIDEO) |
CoronaMike |
Nov 5 2019, 10:13 PM
Member Group: Members Posts: 152 Joined: 11-February 19 From: Maryville, TN Member No.: 22,868 Region Association: South East States |
Hi all -
help! ok - so, had some weird problems today. Which started with the gas pedal sticking at like 75-80 mph on the freeway. I pulled off the fwy and unstuck the pedal - but did it a couple more times on side streets on the way home. But before i made it home - i noticed the engine started making a ticking or pinging sound. Then i got home and let it rest in the garage - but when i came back an hour or 2 later to start it up again - it started making this loud knocking sound. Now I'm more worried about the engine than the pedal sticking. (74 1.8 Ljet) Here's a link to a video of me starting the car Any help would be much appreciated. (IMG:style_emoticons/default/smile.gif) Thanks everyone! mike |
ndfrigi |
Nov 5 2019, 10:23 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
hoping just the valve since it is ticking only when u drive home and got worse when you started it again inside your garage. Try opening both valve cover and inspect.
falcor75 |
Nov 5 2019, 11:28 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
You might also want to do a compression test and see if that gives any further clues.
bdstone914 |
Nov 6 2019, 06:41 AM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@CoronaMike
Mike, Isolate which head it is coming from. Use a hose like a stethoscope. At best a rocker shaft came loose. At worst a rod knock. Pull the valve covers and look at the height of the valves when closed. If you dropped a seat that valve will be highet than the others. I am in Riverside and could take a look at it. PM me your phone number. Bruce 9515367478 |
bdstone914 |
Nov 6 2019, 06:46 AM
Oops
barefoot |
Nov 6 2019, 11:31 AM
Senior Member Group: Members Posts: 1,279 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
That clunk right at the end almost sounds like the flywheel is getting loose.
I had to re-torque mine when still on engine stand. |
CoronaMike |
Nov 6 2019, 12:02 PM
Yikes - well - i'm hoping for the best. Ok - sounds like i'm going to be checking out the valves.
Bruce - thanks for reaching out - I'll definitely contact you. (IMG:style_emoticons/default/smile.gif) Thanks guys! Mike |
Lo-Fi Version | Time is now: 1st June 2024 - 07:37 PM |
