Difficulty/cost of adding an oil cooler |
Thunderchief |
Nov 6 2019, 04:49 PM
Member Group: Members Posts: 145 Joined: 12-August 19 From: Pasadena, CA. Member No.: 23,365 Region Association: Southern California |
My buddy is considering buying a half finished 914 project car that will need a few things including an oil cooler for the 3.2 six. What do shops usually charge for parts and labor generally for this, ballpark? Thanks.
mepstein |
Nov 6 2019, 04:54 PM
914-6 GT in waiting Group: Members Posts: 19,314 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You can do it for $500 - $3,000. To do it right, plan on a minimum of $1,400 for parts and I’m guessing 8+ hours for labor.
thelogo |
Nov 6 2019, 06:19 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
My buddy is considering buying a half finished 914 project car that will need a few things including an oil cooler for the 3.2 six. What do shops usually charge for parts and labor generally for this, ballpark? Thanks. Thats good you asked here ...but if you have to ask You have no idea what your getting into /doing Finishing up half built /6 s is not for the inexperienced.underfunded or indecisive Shops dont work on old ass cars like this anymore Your setting your self up to get ripped off if you ever take it to a shop .... Its not a camry wtf And you do realize your engines survival depends upon the oiling and cooling system being just right |
David Billo |
Nov 6 2019, 06:29 PM
Member Group: Members Posts: 64 Joined: 23-November 17 From: Plainfield, Ontario Member No.: 21,625 Region Association: Canada |
LOL! Gotta love a forum.
Tdskip |
Nov 6 2019, 06:33 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
You can do it for $500 - $3,000. To do it right, plan on a minimum of $1,400 for parts and I’m guessing 8+ hours for labor. ^^^ this. Ben makes good bits for the conversion, worth sending him a PM to get connected. @mb911 There is a lot more to it than the oil cooler BTW, does your friend have a build plan in place? |
mepstein |
Nov 6 2019, 06:46 PM
You can do it for $500 - $3,000. To do it right, plan on a minimum of $1,400 for parts and I’m guessing 8+ hours for labor. ^^^ this. Ben makes good bits for the conversion, worth sending him a PM to get connected. @mb911 There is a lot more to it than the oil cooler BTW, does your friend have a build plan in place? I agree. Talk to Ben / 914-6Werkshop.com There are many good shops that can install an oil system. It’s a pretty simple setup that has been done for decades. Very similar to what’s used in 911’s with some mods to fit a 914. |
porschetub |
Nov 6 2019, 09:40 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Mark said it all,very expensive process,fitting and hose's really add up cost ,don't go metric as AN is so much cheaper and you can get conversion adaptors from Elephant Racing,I payed the price in a big way with metric because when purchased I had most of them but payed dearly for the rest.
The right cooler and thermostat and hard/ soft lines are not chump change by any means. Fitment of oil lines is not beyond DIY but lots of research needed to see how its best done,@ a shop it will be costly so select the right shop with experience...do it once and right. |
Thunderchief |
Nov 6 2019, 11:50 PM
Good point. I'll shoot Ben a message and get his input.
Ben makes good bits for the conversion, worth sending him a PM to get connected. @mb911 There is a lot more to it than the oil cooler BTW, does your friend have a build plan in place? [/quote] |
mb911 |
Nov 7 2019, 06:59 AM
914 Guru Group: Members Posts: 6,882 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
It all depends on what the goal is.. There are plenty of kits out there.. Most of my stuff is meant to look close to original. You could do everything much cheaper with all AN fittings etc but won't look close to correct. My website is www.914-6werkshop.com
sixnotfour |
Nov 7 2019, 08:20 AM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
here is a kit ....for example only, never used one of these..
$2180 does not include the oil cooler and ducting https://www.elephantracing.com/oil-cooling/...r-plumbing-kit/ another $885 for oil cooler and ducting https://patrickmotorsports.com/collections/...14-207-m491-pms lots of different options,, $$$ Attached image(s) |
GregAmy |
Nov 7 2019, 08:24 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Street car? I suggest an under-rear-trunk cooler would be perfectly fine. And easy. And not terrible expensive.
http://www.tangerineracing.com/remotecooler.htm |
ChrisFoley |
Nov 7 2019, 08:27 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I have kits for 4 cyl engines but nothing designed to go with a -6.
Tdskip |
Nov 7 2019, 09:15 AM
Street car? I suggest an under-rear-trunk cooler would be perfectly fine. And easy. And not terrible expensive. http://www.tangerineracing.com/remotecooler.htm As Chris indicated, great kits but not adequate for a 3.2 (or really anything over a 2.2 although there is debate there to some extent from what I have found). |
Cairo94507 |
Nov 7 2019, 09:23 AM
Michael Group: Members Posts: 9,822 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
There are many ways to do this. But for what it is worth, doing it right and once is the best plan in my book. I like Ben's SS lines and products. There are oil coolers available and plumbing it to the front trunk, though a bit more work and expense, I believe is the best solution so you never have overheating issues. If you have time, take look at part two of my build thread to see a finished set up. (IMG:style_emoticons/default/beerchug.gif)
mepstein |
Nov 7 2019, 09:27 AM
Street car? I suggest an under-rear-trunk cooler would be perfectly fine. And easy. And not terrible expensive. http://www.tangerineracing.com/remotecooler.htm I talked to 2 guys at WCR with 3.2’s thT had a rear trunk cooler and moved it to the front since the rear wasn’t enough for spirited driving. I did a front cooler with a fan from the start because I didn’t want to get into a traffic jam and wish I had a front cooler. Porsche did the front cooler on all the 912 3.2’s. |
ClayPerrine |
Nov 7 2019, 09:28 AM
Life's been good to me so far..... Group: Admin Posts: 15,518 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I have a hot 4.0 in my six conversion. I use two 964 oil coolers mounted in the rear with the transmission. The engine has not exceeded 220 degrees since installation. But it has not seen a Texas summer yet.
With the 2.4S motor in the same car, I had a 911 Carrera cooler mounted in the right rear behind the wheel. Nothing was ever run up front. The cooler dropped the engine temp more than 30 degrees and kept the engine cool on a hot Texas summer day. But remember, oil coolers only work when there is a temperature differential between the air and the oil. If the air temp around the trans is 250 degrees, an oil cooler the size of a semi truck radiator mounted there won't drop the temp below 250 degrees. So airflow is paramount. Get the air moving out from under the car, taking the heat with it. Good luck. |
dr914@autoatlanta.com |
Nov 7 2019, 09:31 AM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the oil cooler is best mounted in the front trunk just like the factory did it back then to the 916 and the 914-6 GT cars. Patrick Motorsports sells a good kit
The 3.2 MUST have one when installed in the 914. Largest six cylinder 911 engine in a 914 that can go without one is. 2.4 My buddy is considering buying a half finished 914 project car that will need a few things including an oil cooler for the 3.2 six. What do shops usually charge for parts and labor generally for this, ballpark? Thanks. |
mb911 |
Nov 7 2019, 09:36 AM
the oil cooler is best mounted in the front trunk just like the factory did it back then to the 916 and the 914-6 GT cars. Patrick Motorsports sells a good kit The 3.2 MUST have one when installed in the 914. Largest six cylinder 911 engine in a 914 that can go without one is. 2.4 My buddy is considering buying a half finished 914 project car that will need a few things including an oil cooler for the 3.2 six. What do shops usually charge for parts and labor generally for this, ballpark? Thanks. That said my GT lines look factory |
wes |
Nov 7 2019, 12:09 PM
wes Group: Members Posts: 1,589 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
I used Ben’s lines, Ben/Oscar’s bumper (great looks) and Patrick Motorsport’s kit with their plastic valence. Not cheep but to me it’s a guaranty for unexpected stop and go traffic on hot extremely hot weather.
scallyk9 |
Nov 7 2019, 03:03 PM
Member Group: Members Posts: 323 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest |
I've got '74 with a 3.2L ('87 Carerra motor with MFI) and a under-trunk mounted cooler. I think it depends a lot on your purpose for the car and where you live. The highest temp I have seen was 215 degrees when stopped in traffic for around 20 minutes on a 90 degree sunny day. That said, we will be adding a fan during the current transaxle swap.
Lo-Fi Version | Time is now: 9th June 2024 - 01:19 AM |
