How I spent my Saturday morning, Fun, fun, fun |
BeatNavy |
Nov 9 2019, 12:44 PM
Rather than get myself worked up holding my breath about Mikey914's world premier announcement I decided to tackle one of the truly fun body jobs on my driver this morning. Based on the mess below, care to guess what that was?
Retroracer |
Nov 9 2019, 12:48 PM
Senior Member Group: Members Posts: 616 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
Hmmm.. Looks like 50 year old dried up foam leftovers - rear fender, up near the light housings maybe?
- Tony |
BeatNavy |
Nov 9 2019, 12:58 PM
Hmmm.. Looks like 50 year old dried up foam leftovers - rear fender, up near the light housings maybe? - Tony Indeed! That was too easy, wasn't it (IMG:style_emoticons/default/dry.gif) . Your prize is you get to hear Mark's announcement later today (IMG:style_emoticons/default/first.gif) Anyway, I can sleep better now knowing that rust has yet one less sanctuary to hide on my car. This is the second car I've done this to, and it keeps getting more and more fun. NOT. Foam cleaned out of driver's side, but still some more cleanup to do, including removing the rest of the flaking, 47 year old undercoating. |
trick-e |
Nov 9 2019, 05:35 PM
Still Learning Group: Members Posts: 115 Joined: 7-July 12 From: Traverse City, MI USA Member No.: 14,644 Region Association: Upper MidWest |
I’m all for fun, but don’t know the area you’re describing. Farthest upper end of the rear fender? Never knew there was foam other than in the sails.
BeatNavy |
Nov 9 2019, 05:51 PM
I’m all for fun, but don’t know the area you’re describing. Farthest upper end of the rear fender? Never knew there was foam other than in the sails. Yeah, there's a fair amount of foam under a layer of seam sealer that extends from the fender into the pointy area of the body above the brake light housing. There was some surface rust there after 40+ years, but I'm pleased overall. My other 914 had rusted right through in those areas because the foam and sealer had trapped moisture. The things we do to keep these "entry level Porsches" on the road (IMG:style_emoticons/default/blink.gif) |
trick-e |
Nov 9 2019, 06:38 PM
Thanks for sharing. Another area for me to look at.
Retroracer |
Nov 9 2019, 08:17 PM
I recognized the debris field. (IMG:style_emoticons/default/smile.gif)
Mine was similar, but made easier by the rusted out metal around the RR lights. I could scrape the gunk out easier - once the PO's bondo chunks had been cleared out - but the metal repair was then a little trickier (lots of compound curves there!) - Tony |
ClayPerrine |
Nov 10 2019, 06:18 AM
Life's been good to me so far..... Group: Admin Posts: 15,518 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
There is actually an easier way to remove it.
Carb Cleaner. Just spray it up in the corner, and the foam melts and runs out of the fender. |
BeatNavy |
Nov 10 2019, 06:38 AM
Yeah, I was wondering if there was an easier way, like spraying something up there. Shortly after I started the poking and prodding I thought "I should go post a question on 914Wolrd to see if there's a better way." Then I thought "Nah, you're making progress, keep going." (IMG:style_emoticons/default/headbang.gif)
mepstein |
Nov 10 2019, 07:41 AM
914-6 GT in waiting Group: Members Posts: 19,314 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
There’s quite a few places where foam was injected into the chassis and I think even the rear edge of the rear lid. I’m going to try the carb cleaner on my parts car and see how it goes and what kind of mess it might make. Thanks for the tip.
TargaToy |
Nov 10 2019, 01:45 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 692 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
Lo-Fi Version | Time is now: 9th June 2024 - 04:55 AM |
