NO SPARK PLEASE IGNORE THIS POST, Some help please. |
sydro |
Nov 15 2019, 06:14 PM
Newbie Group: Members Posts: 1 Joined: 15-November 19 From: New Hampshire Member No.: 23,645 Region Association: North East States |
PLEASE IGNORE THIS POST. I FOUND A THREAD WHERE DD EXPLAINS WHAT I NEED TO DO. THANK YOU DD AND THOSE WHO TRIED TO HELP.
I WOULD DELETE THIS IF I KNEW HOW. Hello, I'm new here. Thanks for having me. I'm also sorry to ask this, but I had no luck finding the topic in the search bar. I have a 73 2.0 (4 cyl) with dual carbs and points. I bought the car from someone who had it sitting in a garage for years, so I removed the engine and took it's tin off to make sure I had no blockages. I didn't label the wires because there where so few, how could I screw it up? HAHA! I do think I have them back where they belong... But the car wont start. I did start it before a removed the engine. I have new points and condenser and 12v to the coil. But I have NO SPARK! None from the coil. I do see a small spark at the points as I turn the engine over, but that is it. What am I missing? |
Chi-town |
Nov 15 2019, 09:36 PM
You have the coil wires mixed up probably
betz |
Nov 15 2019, 10:11 PM
Member Group: Members Posts: 76 Joined: 22-October 18 From: San Leandro, CA Member No.: 22,593 Region Association: Northern California |
check if they are pushed on all the way
Oh and new points need to be adjusted usually. I don't know about 914 ones though. |
ndfrigi |
Nov 16 2019, 12:44 AM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Make sure the point is not defective even it is new. Last time my pertronix died and replaced it with new point from my back up for years inside my trunk. I went to many part of ignition system and even to various FI system and ended up using an old points from my core engine after finding out the new points was defective (grounded).
ClayPerrine |
Nov 16 2019, 05:27 AM
Life's been good to me so far..... Group: Admin Posts: 15,509 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Check the low voltage wires on the coil.
Black connects to the positive side of the coil Black with purple stripe connects to the negative side of the coil Green from the points connects to the positive side of the coil. You may need to clean the wires off first. They get cruddy and it becomes hard to see the purple stripe. See if they are connected correctly and get back to us. Clay |
Lo-Fi Version | Time is now: 5th June 2024 - 10:13 AM |
