Headlight brushes, How do they mount |
BPic |
Nov 17 2019, 04:49 AM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
Does anyone have pictures of how the headlight arm brushes mount? (IMG:style_emoticons/default/confused24.gif)
Thanks, Brad |
bobheinonen |
Nov 17 2019, 02:51 PM
Newbie Group: Members Posts: 10 Joined: 16-September 08 From: San Diego, CA Member No.: 9,556 Region Association: Southern California |
Does anyone have pictures of how the headlight arm brushes mount? (IMG:style_emoticons/default/confused24.gif) Thanks, Brad Use pan head phillips sheet metal screws. Bob. |
tailwind22 |
Nov 17 2019, 04:05 PM
Member Group: Members Posts: 88 Joined: 7-November 17 From: Moses Lake, WA Member No.: 21,583 Region Association: Pacific Northwest |
Do they mount on the trunk side or headlight side of the bucket? Please, only informed responses from survivor car owners.
mepstein |
Nov 17 2019, 06:46 PM
914-6 GT in waiting Group: Members Posts: 19,309 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Headlight side
I have 5 early cars with them. I have to take a look tomorrow since at least one of my cars (the ‘70) had some sort of bracket holding the top part. Pics tomorrow. |
Mikey914 |
Nov 17 2019, 07:32 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Mikey914 |
Nov 17 2019, 07:35 PM
And in the front the rubber flap mounts in the rear
You can find the new ones here. We sell with the new rubber flap and the tabs to mount them https://900designs-container.zoeysite.com/e...light-brush-set |
bobheinonen |
Do they mount on the trunk side or headlight side of the bucket? Please, only informed responses from survivor car owners. Headlight side. This is why used units, if you can find them, are usually so rusty. Flip it over to put the convex curve (flat flange) next to the bucket wall. These go on first, then the headlights mount in the buckets. Bob |
Matty900 |
Nov 18 2019, 02:24 AM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
I will be doing a thread on this after we get through getting ready for black Friday.
The Brushes go on the bucket side. At the top is where the metal tab goes to hold down the splash guard (rubber flap) The trick on this is that the rubber goes up and over the top. This ultimately causes it to fatigue and rip (and that is why they replaced this system with a boot on the backside over the pushrod from the motor.) To ease the fatigue of the rubber, the metal tab has a bend to it that faces away from the wall to ease the bend just a little. If you have the bend go towards the wall and pinching the rubber, you will just cause it to wear out faster. This rubber flap will wear out. Think of it when you change your wiper blades. It is a consumable part that will wear over time. Attached thumbnail(s) |
Matty900 |
Nov 18 2019, 02:40 AM
Here is an original part for comparison and the prototype part when we were test fitting so you can see how they mount. It's intended to keep water and dirt out of the trunk. This keeps it on the side where the drains are.
Hopefully this answers the questions. (IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
rgalla9146 |
Nov 18 2019, 08:10 AM
Advanced Member Group: Members Posts: 4,564 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Do they mount on the trunk side or headlight side of the bucket? Please, only informed responses from survivor car owners. Headlight side. This is why used units, if you can find them, are usually so rusty. Flip it over to put the convex curve (flat flange) next to the bucket wall. These go on first, then the headlights mount in the buckets. Bob Dont forget these little tin parts on the top screw. Attached thumbnail(s) |
BPic |
Nov 18 2019, 03:41 PM
dr914@autoatlanta.com |
Nov 18 2019, 03:51 PM
914 Guru Group: Members Posts: 7,890 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
remember only 70-72 used them
Lo-Fi Version | Time is now: 4th June 2024 - 08:14 PM |
