Brake hose clips, brake hose to chassis |
rgalla9146 |
Nov 30 2019, 11:38 AM
Advanced Member Group: Members Posts: 4,561 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Is one more correct than the other ?
The thin springy one or the stout thick one. For a 1970 car. Attached thumbnail(s) |
johnhora |
Nov 30 2019, 01:05 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
I've usually seen the left one....thin springy
mb911 |
Nov 30 2019, 04:16 PM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
914Sixer |
Nov 30 2019, 08:10 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
The left one is a VW clip, used on all models of that era. The other is what they are selling as a replacement is a fender spacer in my opinion.
Attached image(s) |
gms |
Nov 30 2019, 10:15 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
bdstone914 |
Dec 1 2019, 05:59 AM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Is one more correct than the other ? The thin springy one or the stout thick one. For a 1970 car. Clip on the right is correct for 1970 (IMG:style_emoticons/default/agree.gif) Early 914's and 911 used the thicker clip. They changed to the thinner clips, maybe in 72. |
rgalla9146 |
Dec 1 2019, 07:08 PM
As I suspected.
I have many of those on the right. Few of the other. Both work. The stout ones attach the fitting very securely and are well known to be difficult to remove. Thank you guys. |
mepstein |
Dec 1 2019, 08:15 PM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Rory- I didn’t realize there was a difference until you pointed it out. I have some of each. If you are short a couple for a build, let me know.
@rgalla9146 |
rgalla9146 |
Dec 1 2019, 09:00 PM
Rory- I didn’t realize there was a difference until you pointed it out. I have some of each. If you are short a couple for a build, let me know. @rgalla9146 Thanks for the offer Mark. After confirming, I found the originals I had plated. This came up because the first two I installed (the thin ones) were just too easy. Removal of the thick ones can be a challenge, especially on good paint. |
Lo-Fi Version | Time is now: 1st June 2024 - 10:19 AM |
