Front brake back plate question |
rcarson25 |
Dec 1 2019, 06:25 PM
Member Group: Members Posts: 62 Joined: 15-May 17 From: TN Member No.: 21,103 Region Association: South East States |
I am building my 1970 right now and I apparently have 1 early front brake rotor backing plate/ dust shield. I have a late parts car and have both front rotor backing plates from that. These early and late look different, but are they interchangeable? I have an early brake setup from pmb on the way and I need to figure out if I need to search for another early backing plate or if I can clean up the late model ones and run with those. Thanks in advance.
914Sixer |
Dec 1 2019, 06:40 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Early and late are do not interchange due of brake caliper offset. Any reason you did not use the late set up?
injunmort |
Dec 1 2019, 06:52 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
if it will bolt on without interference and originality is not a concern, I would try it. early and late struts differ in offsets, so calipers and rotors differ, I don't know if the dust shields would make a difference. no ruby, no problem. buts that's me.
rcarson25 |
Dec 1 2019, 07:04 PM
Lo-Fi Version | Time is now: 2nd June 2024 - 02:13 AM |
