heater hoses, too small? |
smooth_eddy |
Jul 2 2005, 04:16 PM
Senior Member Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 |
How do I get the new heater hoses back on? The old ones are paper with aluminum inners. The new ones are all aluminum and the hose seems to be the same size as the opening on the heat exchangers and fitting that goes thru the longs. Did I buy the wrong size? Eddy
ejm |
Jul 2 2005, 04:28 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,693 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The original hoses are cloth like with a rubber coating and have a spiral wire inside to maintain the shape of the hose. As the engine rocks on its mounts there is quite a bit of movement between the heater outlet and the long. I think you may have the wrong type of hose for this location.
rhodyguy |
Jul 2 2005, 04:38 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,092 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
did you buy them from a vw shop? if you did they are probably for type1.
k |
smooth_eddy |
Jul 2 2005, 04:44 PM
I did buy the hose from a VW shop. They said it was a 911 part #. It does seem like it is about an 1/8" smaller than what I took off. The orig is hard to measure because it is so beat up.
rhodyguy |
Jul 2 2005, 04:48 PM
bow wow? you're going to be shocked when you price out the "correct" tubing at one of the usual vendors. hope you can return what you bought.
k |
smooth_eddy |
Jul 2 2005, 04:56 PM
Yep, it was Bow Wow.........Just trying to give a local biz some business. Heck, I thought $7.57 was a lot for 6" of hose. Guess I'll be duct taping up the old one for a while anyway. Thanks, Eddy |
rhodyguy |
Jul 2 2005, 05:04 PM
$7.57 for 6 inches? (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) oh, you mean 6'. whew (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
k |
smooth_eddy |
Jul 2 2005, 05:56 PM
$7.57 for six inches.............. I bet that means I can expect $757.oo from AA???, Plus too much for shipping???? |
Lo-Fi Version | Time is now: 8th June 2024 - 05:00 PM |
