Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,740 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
Is there a best practice I should be aware of here as I continue to plan this out?
Thanks! |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,057 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Behind the driver or passenger seat most often.
Once I clean up some wires, I want to see if I can get it to the passenger footwell. If I can't, It may go between the seats in a little custom cover. It should always be kept dry and cool. |
Tdskip |
Ha, so extra long extension cord or someone running with it next to the car is not an option. Got it. @mepstein - are you planning on modifying the interior backpad or, instead, passing it through and mounting it on the interior side of the backpad? Sounds like that later. Thanks! |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,517 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
I put mine under the foam block on the passenger footwell. But I had to extend the DME harness to make it reach.
If I were going to do it again, I would put it in the middle of the car under the back pad. |
Tdskip |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,311 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Under the dash on the passenger side ...
(IMG:style_emoticons/default/popcorn[1].gif) |
mepstein |
I don’t think mine will reach but that would be the perfect spot. |
ClayPerrine |
Where? I couldn't find a spot under there. Do you have a picture? |
Tdskip |
Don’t think mine will reach either, great spot however
mepstein |
Ha, so extra long extension cord or someone running with it next to the car is not an option. Got it. @mepstein - are you planning on modifying the interior backpad or, instead, passing it through and mounting it on the interior side of the backpad? Sounds like that later. Thanks! I went through the “dimple” on the lower part of the firewall, behind the right seat. I did cut short the stock early backpad by about 2 inches on that side. Doesn’t show behind the seat since I left the viny and it covers the wire bundle. Eventually I will replace with a later adjustable seat and perlon. |
SirAndy |
Where? I couldn't find a spot under there. Do you have a picture? http://www.914world.com/bbs2/index.php?s=&...st&p=883879 The PMS harness was actually long enough to mount the brain horizontally under the dash in the position where Mark is holding it vertically in the picture. We mounted it on a custom frame using rubber isolators to counteract vibrations. It's tucked away so nicely that you can't see it at all unless you get your head under the dash ... (IMG:style_emoticons/default/smile.gif) |
SirAndy |
The PMS harness was actually long enough to mount the brain horizontally under the dash in the position where Mark is holding it vertically in the picture. We mounted it on a custom frame using rubber isolators to counteract vibrations. It's tucked away so nicely that you can't see it at all unless you get your head under the dash ... (IMG:style_emoticons/default/smile.gif) @ClayPerrine @mepstein http://www.914world.com/bbs2/index.php?s=&...st&p=893545 (IMG:http://www.914world.com/bbs2/uploads/post-179-1177645321.jpg) |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,927 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Mine fits perfect behind the drivers seat. I use a longer backpad screw to hold it in place. The DME relay and altitude sensor is behind the passenger seat. Did not have to modify any of the cables.
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,943 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Don’t think mine will reach either, great spot however (IMG:style_emoticons/default/santa_smiley.gif) (IMG:style_emoticons/default/santa_smiley.gif) just another..what if thread.....rear trunk ..under seat, under glove box.. Surprise Us .... |
Tdskip |
Don’t think mine will reach either, great spot however (IMG:style_emoticons/default/santa_smiley.gif) (IMG:style_emoticons/default/santa_smiley.gif) just another..what if thread.....rear trunk ..under seat, under glove box.. Surprise Us .... @Steve - I noticed you don't have a sound pad in the engine compartment, how is the noise level for longer trips? @sixnotfour - nope, not a "what if" thread, a making sure when I do it early next year I get it right having learned from the people here thread. Tell you what - want to bet $1,000 it gets done? |
Maltese Falcon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,107 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None ![]() ![]() |
I've seen a few conversions where the DME/ alt-comp + dme relay were cleanly mounted in the rear trunk. Still able to store the targa top. I like the accessibility of getting to the relay, it can be popped out on occassion...adds another level of anti-theft (IMG:style_emoticons/default/smile.gif)
sixnotfour |
http://www.914world.com/bbs2/index.php?showtopic=116617
(IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/santa_smiley.gif) Attached image(s) ![]() |
sixnotfour |
Attached image(s) ![]() ![]() |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,427 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Mine is under the driver's seat. Definitely wanted it in the interior of the car.
Lo-Fi Version | Time is now: 7th September 2025 - 10:56 AM |
