Maltese Falcon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,077 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None ![]() ![]() |
I've been around fuel cells and know that they require maintenance and replacement of the bladders...but this is on a customer's gt build; foam baffles inserted into the 100L tank. Yep...correct, several years ago these were inserted into the tank , I can only guess for keeping the slosh down and now these have disintegrated inside the tank.
Any fuel tank gurus out there, I know that cutting the tank open/and fabricating it back together is an option, but looking for solutions. ![]() |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,919 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
cut up cubes or balls ..stuff through filler neck....there is no any reason to cut the og tank or make a replacement......I did it on a Cobra...
sixnotfour |
How is That Guy anywaysss....heard he had a replica built ???
Maltese Falcon |
sixnotfour |
Yes Cleaning out the old was tough,,small handed helper helps alot..
PlaysWithCars |
Senior Member ![]() ![]() ![]() Group: Members Posts: 536 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest ![]() ![]() |
Could you dump a solvent into the tank that will dissolve the old baffles? Lacquer thinner maybe? (IMG:style_emoticons/default/confused24.gif) Then put in the replacement chunks per Jeff's suggestion.
wndsrfr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,455 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region ![]() ![]() |
Flush with water and detergent....Dry it. Maybe 24 hours air blow..use shop vac to get residue out.
Still you won't get it all so I would leave off the in tank screen and put a racor plastic bowl filter on it to separate the inevitable stuff out. Actually better to scrap the tank & install new.. .. |
sixnotfour |
QUOTE Actually better to scrap the tank & install new.. .. its a factory GT 100 liter tank..... |
Maltese Falcon |
Foam problem solved...thank you all for your input !
Next up is the 2nd tank...it has a filler cap that has "Mated" itself to the filler neck...won't budge and we are not looking to butcher it off of its resting place either (IMG:style_emoticons/default/sad.gif) We came up with soaking the filler neck with pB blaster for a week, and trying to wrench it off with a toothed-neoprene belt ; no-go. More pB soaking, and another few days with the tank inverted for more soak...nada So my bud found an adjustable "Pin" wrench online, did a bit of custom contour grinding and presto >> hit the jackpot. ![]() |
Maltese Falcon |
Maltese Falcon |
sixnotfour |
Lo-Fi Version | Time is now: 31st July 2025 - 10:56 AM |
