FS: Subaru Conversion Parts, EG33 & MT5 Mount , SubaruGears, and OBX, Gates |
914forme |
Jan 4 2020, 11:52 AM
I have a few parts for an EG conversion.
Small car mount modified for early bar, also have the bulk head piece but mount on firewall would have to be fabricated. What you have is mounts that install on the -4 mounts on the side of the engine compartment. They mount to an early 914-4 crossbar. You supply this mount, as I think shipping might be a tad to much. The small car mount then sets onto of the bar. And then the MT5 rear mounts. All built with isolation mounts from Energy suspension. New OBX MT5 limited slip diff for a Subaru MT5 - unit has been fully gone through all metal flashing removed in the diff. Screws, washers, and thrust surface washers replaced with hardened materials. Extra set of the hardened washers, screws and thrust washers. $10 shipped. Not sure why I have an extra set (IMG:style_emoticons/default/confused24.gif) Subaru Gears 108mm axle flanges for the MT5. New, only installed for mocking up, new Subaru pins for the flanges. Gates Green Stripe Hose enough to go front to back on a 914 chassis. Return line is 1-1/4 the hot side is 1" |
JRust |
Jan 4 2020, 03:22 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I'll take the LSD please (IMG:style_emoticons/default/biggrin.gif)
914forme |
Jan 4 2020, 03:26 PM
Sale pending on the LSD
burton73 |
Jan 4 2020, 11:05 PM
burton73 Group: Members Posts: 3,540 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
GermermanCarGuy |
Jan 5 2020, 09:54 AM
GermanCarGuy Group: Members Posts: 81 Joined: 13-May 14 From: Rapid City, SD Member No.: 17,346 Region Association: Upper MidWest |
I'll take the axle flanges and Gates hose.
Shipping to 57703. Let me know total cost and PayPal. Does this mean you're no longer building your Signal Orange 74? RobF |
914forme |
Jan 5 2020, 02:00 PM
I will get them boxed up and figure out shipping cost for you.
Long of the short the car will not be built by me, a few things came up. Guess I should update the tread, I'll do it tonight just checking in between other projects. |
914forme |
Jan 15 2020, 05:52 PM
Picture added for extra upgrade bolts and washers for OBX LSD Differential.
Lo-Fi Version | Time is now: 4th June 2024 - 05:46 AM |
