> gauge swap, 911 oil temp/pressure
Triaddave
post Jul 3 2005, 11:21 AM
I found a really cool gauge from an early 911 to install into my 914. the pressure side works great, but the temp side pegs out. do i need the correct sender to make this thing work? all the wiring from sender to gauge checks out, and the orginal sender from the 914 worked before the install. is it the gauge or the sender?
Replies(1 - 17)
Bleyseng
post Jul 3 2005, 11:43 AM
Aircooled Baby!
You need the correct early 911 sender.
Joe Bob
post Jul 3 2005, 11:45 AM
How early is early? I just removed one from a 2.0/6.....it works, but not with my later VDO gauge....
Bleyseng
post Jul 3 2005, 11:54 AM
Aircooled Baby!
maybe this will help
Joe Bob
post Jul 3 2005, 01:16 PM
Hmmmm, no serial number on the oil temp sender...it DOES have 11/67 on the side. I assume that is a build date. It's yours for the cost of shipping if you want to try it.
The one that "I" needed cost 45 bucks... (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif)
rhodyguy
post Jul 4 2005, 07:23 AM
i have a euro gauge i've wanted to put in for some time. only number i can find is 0033. you can't see it when the unit is in the housing. 0033 isn't listed in that chart geoff. any ideas? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
k
Bleyseng
post Jul 4 2005, 09:47 AM
Aircooled Baby!
Kevin, order one of each and test the gauge with the senders in boiling water. Send the wrong one back. (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif)
Aaron Cox
post Jul 4 2005, 09:48 AM
Professional Lawn Dart
so a 911 sender will screw directly into the taco plate?
too cool
AA
rhodyguy
post Jul 4 2005, 09:55 AM
well i guess i could do that. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) or, just call north hollywood speedo, give them the numbers and see what they suggest. or, spend $500 and buy one of their gauges ready to go. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) yes aaron you just have to know which one is the appropriate sender. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) it doesn't screw in. you have to pull the taco plate to access the retaining nut on the backside, and then figure out what you will use for the gaskets that are nla.
k
Aaron Cox
post Jul 4 2005, 10:07 AM
QUOTE (rhodyguy @ Jul 4 2005, 08:55 AM)
k
i got the same numbered 911 gauge as you do...and i also need a 10bar pressure sender (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
100 bucks in senders....yikes
Joe Bob
post Jul 4 2005, 10:10 AM
Buying the sender WITH the gauge is cheaper than buying seperate.....you can try MY temp sender for the cost of shipping....if it doesn't work, sell the gauge and sender seperately to some schmuck on evilbay (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Then buy the properly matched one(s)....
rhodyguy
post Jul 4 2005, 10:18 AM
mike, if you have a couple of diff senders i would sure enjoy pulling the taco plate numerous times. then converting *c to *f with my rectal thermometer. sorry for the (IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif) dave. if you can get the numbers off the gauge north hollywood can prob set you up with what you need www.nhspeedometer.com.
k
Joe Bob
post Jul 4 2005, 10:21 AM
Just have the one.....that came off of Manfred's power plant. I have some T4 ones around some place....
Triaddave
post Jul 4 2005, 11:36 AM
thanks to everyone for the input. we tried the gauge on a different car, a 914/6, and the darn thing pegged again. i was sure looking at that gauge with the press/temp and the fuel, that would be ideal. the thought was to connect the low fuel light to the parking brake light. a fuel gauge would be nice...
Joe Bob
post Jul 4 2005, 11:42 AM
The gauge should have four wires....ground, sender, power and light power.....got them hooked up right?
Triaddave
post Jul 4 2005, 11:48 AM
yes, all the wires are connected correctly,doubled checked and checked again....aaarg.
Joe Bob
post Jul 4 2005, 11:51 AM
OK...cause pegging usually means something is hooked up wrong.
VDO has a trouble shooting guide on their website and I'm sure they have pics or the matching senders...
BTW...I assume that the wires have been checked for breaks/ground faults with a voltmeter or Fluke?
Bleyseng
post Jul 4 2005, 12:10 PM
Aircooled Baby!
Yeah, sounds like a short otherwise it should just read goofy if its the wrong sender.
Kevin, you can try it with my sender if you want. We can boil some water and check it out. The sender is sitting on the workbench at the shop.
- Lo-Fi Version Time is now: 31st July 2025 - 05:14 AM
