Fuel Gauge Issue, Everything looks right. |
toecutter |
Jul 3 2005, 01:30 PM
Kid Close Enough Group: Members Posts: 37 Joined: 6-March 05 From: Sherman, Texas Member No.: 3,723 |
What am I missing? No matter how much gas is in the tank it reads empty. Took the sender out and tore it apart and cleaned it up as per the tech article on PP site. It looked pretty good. Still reads empty. The guage twitches a little whenever you turn on the ignition. I traced the wires from the sender to the back of the dash and can't find any gnaw marks from the furry friends who used to live in there (their bathroom was right by the place the loom goes through the firewall). Is there something else I could check?
P.S. Finally got my cheap tires balanced. 90 mph @ 3800 rpm in 5th. Woohoo! Attached image(s) |
Brando |
Jul 3 2005, 01:41 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Possibly the gauge itself is bad? I think there's a certain Ohm reading it's supposed to have? Not too sure though.
914GT |
Jul 3 2005, 01:53 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
Rule out the gauge/wiring by grounding one of the wires at the tank connector and it should peg the gauge to full. Ground the other one and the low fuel light should come on. This is with the ignition switch on. If both work then the problem is still in your sender.
Lo-Fi Version | Time is now: 7th June 2024 - 10:54 AM |
