Tuna can question on a 2.0l case |
Tdskip |
Jan 22 2020, 01:36 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning gentlemen, have a question on moving a tuna can from one 2.0l case to another. It appears that it all should just transfer over if it is a good quality assembly, right? The 2.0L turbo engine I removed has one, the 2.0L engine I installed does not.
And yes, I will make sure there is no actual tuna in the can first. Thanks! |
914werke |
Jan 22 2020, 01:42 PM
"I got blisters on me fingers" Group: Members Posts: 10,138 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Just gasket(s) & crush washer. Is this the old Welt. steel can?
Tdskip |
Jan 22 2020, 02:12 PM
Hi. Not sure of the make, will try to get some pictures.
914werke |
Jan 22 2020, 02:29 PM
Tdskip |
Jan 22 2020, 02:30 PM
Haven't pulled it yet, curious what I will find.
Mark Henry |
Jan 22 2020, 03:33 PM
All 914 T4 cases are the same.
Only some very early VW 411 T4 early 1.7 cases were mag and/or had no provision for a windage tray, but I've never seen one. |
Tdskip |
Jan 22 2020, 09:39 PM
Thanks Mark
stownsen914 |
Jan 22 2020, 11:32 PM
Senior Member Group: Members Posts: 916 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I like the screen in the pic above. I seem to recall that the Weltmeister tuna can I installed on a '74 2.0 I had a long time ago didn't have a provision for a screen. I think I fashioned something, but it wasn't pretty.
falcor75 |
Jan 23 2020, 07:25 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Dont overtighten it when you put it back!
Tdskip |
Jan 23 2020, 10:26 AM
Is the idea of the screen that it will help trap any crud that settles to the bottom of the can since it is the low point in the oil system?
Thanks for all of the responses. |
914werke |
Jan 23 2020, 10:40 AM
No, more in case of a catastrophic event to keep large chunks of material from being sucked into the pickup
Mark Henry |
Jan 23 2020, 08:10 PM
Dont overtighten it when you put it back! IMHO every 914 or any T4 owner should have an inch pound torque wrench. The oil sump plate is 9 ft/lbs which is 108 inch/lbs...not a pound more. I also work on 996/7 engines, lots of M6 bolts in alunimum, 7.5 Ft/lbs, no inch pound torque wrench and you'll be heli-coiling a lot of holes. On 914 every engine I build I helicoil the taco plate bolt holes. I've had to replace a few cases due to over torquing the sump plate resulting in a broken bolt boss, including one on a customers brand new performance engine. |
Lo-Fi Version | Time is now: 8th June 2024 - 08:52 AM |
