> FI cold start valve need advise, 1974 914 1.8
brcacti
post Jan 30 2020, 05:18 PM
Hello, my experienced VW mechanic put in my xr700 electronic ignition he said it runs well but said my bad fumes may be a FI cold start valve sticking. Would love to get mechanics input from this forum on that, is it easy or hard to put in, can a non mechanic put that in and how much about does it cost for one?
Thank you
Replies(1 - 19)
TheCabinetmaker
post Jan 30 2020, 05:28 PM
I drive my car everyday
Just disconnect the hoses and attach a double ended barb connector. Your in AZ. You don't need it. It doesn't work till temps hit 39 degrees
TheCabinetmaker
post Jan 30 2020, 05:34 PM
Where do you smell the gas?
Rand
post Jan 30 2020, 05:37 PM
Cross Member
Your profile says you are in Phoenix. I doubt your CSV is even in the equation. You can bypass it to test. Just eliminate it from the mess for now.
dr914@autoatlanta.com
post Jan 30 2020, 05:49 PM
Probably not the valve, could be the air flow meter flap sticking, the air gap not set on the electronic ignition or the timing not correct, or low compression due to bad valve adjust and or a bad head temp sensor
. The cold start valve on the 1.8 fires at 60 degrees or colde
QUOTE(brcacti @ Jan 30 2020, 04:18 PM) *
Thank you
Rand
post Jan 30 2020, 06:09 PM
Cross Member
Sounds like the doc is in ljet mode. Is this Djet?
brcacti
post Jan 30 2020, 06:27 PM
QUOTE(Rand @ Jan 30 2020, 05:09 PM) *
I think L jet as someone guessed before, I have no idea (IMG:style_emoticons/default/smile.gif)
pete000
post Jan 30 2020, 06:41 PM
Bad fumes? could it just be a bad charcoal filter to the gas tank? I hear they can die.
brcacti
post Jan 30 2020, 06:52 PM
Seems to me to be running very rich saw gas fumes in the rear of the car, does not appear to be using any oil. level stays the same
rjames
post Jan 30 2020, 07:01 PM
I'm made of metal
Are all of the FI components original and/or correct for your engine?
brcacti
post Jan 30 2020, 07:28 PM
QUOTE(rjames @ Jan 30 2020, 06:01 PM) *
YES, everything is original as far as I can tell, the experienced VW mechanic said also original distributor when installing the electronic ignition today. Seems to be running very rich saw gas fumes coming out the rear at times, no use of oil and dip stick seems to stay the same level.
Rand
post Jan 30 2020, 08:48 PM
Cross Member
If you are seeing "fumes" out the exhaust something is way off. Does it have more of a white or blue tint?
TheCabinetmaker
post Jan 31 2020, 08:33 AM
Pull all the spark plugs and check for one that's wet, or very black.
post Jan 31 2020, 10:30 AM
the initial subject was designated as 74 1.8, so I figured that was for which fuel injection system he needed advice. The main problem calling rich running is the sticking air flow meter flap caused by lean backfire
brcacti
post Jan 31 2020, 01:11 PM
QUOTE(dr914@autoatlanta.com @ Jan 31 2020, 09:30 AM) *
Hello,.......................is the air flow meter flap the SAME PART as the cold start valve?
jcd914
post Jan 31 2020, 01:21 PM
QUOTE(brcacti @ Jan 31 2020, 11:11 AM) *
No the Cold Start Valve and Air Flow Meter Flap are quite different.
Cold Start valve don't fail that often.
To test, you can easily disconnect the fuel supply hose and plug it off and see if your "overly rich" smell goes away.
What diagnosis did your mechanic do before suggesting it might be the Cold Start valve?
Overly rich L-jet is usually an Air Flow Meter problem.
Jim
ndfrigi
post Jan 31 2020, 01:25 PM
cold start valve
air flow meter
brcacti
post Jan 31 2020, 02:17 PM
Hello, here is a pic of my cold start valve I assume it is left of the two hoses and blue electrical part inside the metal tube ???Attached Image
ndfrigi
post Jan 31 2020, 02:36 PM
brcacti
post Jan 31 2020, 05:02 PM
QUOTE(dr914@autoatlanta.com @ Jan 30 2020, 04:49 PM) *
Thank you
Thanks, since my mechanic installed the xr700 today and advanced the timing 5 or 8 plus I need to wait to see if I have the bad smells any longer since a few people mentioned that the timing could be the problem, I think he changed it, so I guess I have to wait and observe for now, runs good
- Lo-Fi Version Time is now: 30th April 2026 - 01:06 PM
