Did ‘72 come with defroster in rear glass? |
stevegm |
Feb 1 2020, 11:53 AM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
I have three rear glasses and I’m not sure which is for my ‘72?
Beebo Kanelle |
Feb 1 2020, 12:24 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
Mine did
Mark Henry |
Feb 1 2020, 12:36 PM
Some did, southern states destined cars usually didn't have them. Only a couple bucks of parts and labour, but lets say that X 50K of production was southern states, adds up. Typical of VW, they made a couple bucks extra on southern cars.
The wife's '72 and my '74 both have the rear defroster. |
sixnotfour |
Feb 1 2020, 12:55 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Check for wiring...
Cairo94507 |
Feb 1 2020, 12:58 PM
Michael Group: Members Posts: 9,815 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Do you have a rear window defrost knob on the dash?
914Sixer |
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Check for continuity of the sliver color lines. 95% are bad.Put volt ohm meter across the spades on the window, see if it 0's out. Most will have a high open.
dr914@autoatlanta.com |
Feb 1 2020, 01:30 PM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
anderssj |
Feb 1 2020, 01:32 PM
Dog is my copilot... Group: Members Posts: 1,663 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
IIRC, you could order it on a new car as an option--I think for less than $100. I retrofitted my car (early 1972) years ago while stationed in Seattle area, but I don't think the wiring was there. I salvaged wires, switch, etc, from a wrecked car.
stevegm |
Feb 1 2020, 01:59 PM
Check for wiring... Good idea. I assume the defroster wire comes out of the center tunnel? Here is what I have. I’ll have to dig into it. Attached thumbnail(s) |
rgalla9146 |
Feb 1 2020, 02:10 PM
Advanced Member Group: Members Posts: 4,564 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I think all early chassis had the wiring in the harness.
Every 6 I've worked on had it at the back of the tunnel. |
Lo-Fi Version | Time is now: 3rd June 2024 - 09:51 AM |
