12 - Pin Jumper?, I don't have one |
BPic |
Feb 2 2020, 10:30 AM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
All of the 12-pin diagrams I see have a green jumper wire from pin 11 to pin 10. I don't have this on my 72. It's a 2056 with carbs if that matters. (IMG:style_emoticons/default/confused24.gif)
Do I need to add it? What is it for or what are the benefits? Thanks!! |
bbrock |
Feb 2 2020, 10:45 AM
Edit: It shuttles power to the heater fan relay. You probably don't need it.
BPic |
Feb 2 2020, 10:48 AM
Thanks @bbrock looks like I’ll need to add it.
bbrock |
Feb 2 2020, 10:51 AM
I just edited my reply after taking a closer look at the schematic. IIRC, your are deleting your heat so don't need it? |
BPic |
Feb 2 2020, 10:54 AM
Correct. No heat. I just unwrapped the rest of the engine harness and the green to pin 11 and the white to pin 12 are cut and taped.
bbrock |
Feb 2 2020, 11:00 AM
Correct. No heat. I just unwrapped the rest of the engine harness and the green to pin 11 and the white to pin 12 are cut and taped. Reading from the 73 schematic: White to pin 12 connects to pin 13 on the 14-pin connector and both pins take power from the fuel pump relay? |
BPic |
Feb 2 2020, 11:05 AM
Correct. No heat. I just unwrapped the rest of the engine harness and the green to pin 11 and the white to pin 12 are cut and taped. Reading from the 73 schematic: White to pin 12 connects to pin 13 on the 14-pin connector and supplies fuel pump. Was your pump relocated with power tapped from somewhere other than the black/red wire? Well the harness is a hack job that I’m rebuilding with 2 harnesses. I put the pump up front and can tap into the original wires. May need to take a break from it. Looking at 2 harness both were hacked a bit. It’s getting a little confusing!!! |
JeffBowlsby |
Feb 2 2020, 11:53 AM
914 Wiring Harnesses Group: Members Posts: 8,527 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
A 72 ignition harness does not jumper pins 10-11. The fan on a 70-72 car has individual wires from 10 & 11 routing directly to the fan in the ignition harness. The fan on a 73-76 car is fed from two wires branching out of the chassis harness. Don’t confuse the two, they are different.
bbrock |
Feb 2 2020, 12:14 PM
A 72 ignition harness does not jumper pins 10-11. The fan on a 70-72 car has individual wires from 10 & 11 routing directly to the fan in the ignition harness. The fan on a 73-76 car is fed from two wires branching out of the chassis harness. Don’t confuse the two, they are different. Thanks Jeff! Yes, I was responding based on a 73 and POs car is a 72. Good catch! |
Lo-Fi Version | Time is now: 3rd June 2024 - 06:47 AM |
