multimeter setting for checking power to fan/defrost light, 1974 914 1.8 |
brcacti |
Feb 2 2020, 12:02 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Superhawk996 |
Feb 2 2020, 12:10 PM
914 Guru Group: Members Posts: 5,913 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Yup. Will handle up to 20 volts DC (20 VDC). You're only expecting 12-14 volts.
Most digital mulit meters are overload protected so even if you tried to check 12VDC on the 2 VDC setting you'll probably just get a display of OL. Check you're owners manual 1st before intentionally overloading it though! If you want to test continuity of a circuit, you'll need to swith to OHMs and make sure the circuit is not powered. |
Lo-Fi Version | Time is now: 14th June 2024 - 08:02 AM |
