| brant |
Feb 4 2020, 10:38 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,159 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
do the VR gasket sets come with front and rear main gaskets?
I have a kit that I think is new I've been trying to see what it may be missing or is it complete? and I don't see front and rear main gaskets... but don't see anything else missing and not sure the kits even come with the main gaskets? I'm cleaning out the garage and intend to sell a lot of junk in the near future but definitely do no want to mis-represent, so would love informed opinion about whether or not this is a complete gasket set. TIA brant Attached thumbnail(s) |
| Nogoodwithusernames |
Feb 4 2020, 10:50 AM
Member ![]() ![]() Group: Members Posts: 304 Joined: 31-May 16 From: Sutter, CA Member No.: 20,051 Region Association: None |
I'm mid rebuild right now on a t4 motor and none of the gasket sets I've seen include the main seals.
Depending on what size this is for I may be interested when you get things listed up. (Edit: looks like it's for a 2.0 based on the intake gaskets so won't work on the 1.7 I'm working on.) |
| brant |
Feb 4 2020, 10:56 AM
I'm mid rebuild right now on a t4 motor and none of the gasket sets I've seen include the main seals. Depending on what size this is for I may be interested when you get things listed up. (Edit: looks like it's for a 2.0 based on the intake gaskets so won't work on the 1.7 I'm working on.) thank you! |
| brant |
I'm mid rebuild right now on a t4 motor and none of the gasket sets I've seen include the main seals. Depending on what size this is for I may be interested when you get things listed up. (Edit: looks like it's for a 2.0 based on the intake gaskets so won't work on the 1.7 I'm working on.) its a 2.0 I'll put it in the classifieds today or so... |
| Mikey914 |
Feb 4 2020, 10:58 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
oil pump gasket is missing
| brant |
Feb 4 2020, 11:02 AM
| 914Sixer |
Feb 4 2020, 11:43 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,433 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Paper gasket and it should be in the kit. Main seals never included.
| porschetub |
Feb 4 2020, 12:13 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,040 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Have used the VR sets but never seen front and rear seals included,good thing really as I don't like the rear main seals they make anyway,everthing else supplied seems fine as per my last build.
I bought 2 sets many years ago and I'am surprised how much more they cost now (IMG:style_emoticons/default/sad.gif) . |
| brant |
Feb 4 2020, 12:18 PM
| dr914@autoatlanta.com |
Feb 4 2020, 12:49 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the 914 never came with the front and rear main seals unlike the 356 and 911 kits, nor did it come with the windage tray seals (which we had to have made)
do the VR gasket sets come with front and rear main gaskets? I have a kit that I think is new I've been trying to see what it may be missing or is it complete? and I don't see front and rear main gaskets... but don't see anything else missing and not sure the kits even come with the main gaskets? I'm cleaning out the garage and intend to sell a lot of junk in the near future but definitely do no want to mis-represent, so would love informed opinion about whether or not this is a complete gasket set. TIA brant |
| 76-914 |
Feb 4 2020, 02:07 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,870 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
I can't remember which brand I used about 10 years ago but the windage tray seals were in there. I remember looking at them and thinking what do these fit? Once I split the car I saw them and knew. Front a & rear mains, no. I bought those from some VW Bus supplier as the rear main was mentioned as being superior to others. I bought the OEM main bearings from you George. They were unobtanium at that time.
| brant |
Feb 4 2020, 04:23 PM
Thanks again for all of great input!
I looked again at the set. Shook it to see the gaskets better I think this is the oil pump gasket (with the 4 bolt holes) Attached thumbnail(s) |
| motorvated |
Feb 4 2020, 05:38 PM
Member ![]() ![]() Group: Members Posts: 282 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
My gasket kit did not come with front or rear main seals. It came with one oil pump cover gasket, as does yours, when it appears that the oil pump housing on my engine has another paper gasket between it and the case which was not provided.
Not to high jack this thread, but what are the eight white ribbed plastic sleeve-like things that are shown in the plastic bags in the first couple of photos. My gasket kit also has them, but I haven't seen anything like them in/on my motor. |
| injunmort |
Feb 4 2020, 05:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
vibration dampners for the cylinder studs used on a bus.
| 914Sixer |
Feb 4 2020, 06:02 PM
Vibration dampers go on all type 4 engines.
| motorvated |
Feb 4 2020, 06:20 PM
Vibration dampers go on all type 4 engines. If I'm not mistaken, there are 16 cylinder head studs on Type 4 engines, and only eight of these vibration dampeners in the kit. Install two per cylinder? Install them where, bottom of cylinder, top of the heads? I'm confused. |
| BeatNavy |
Feb 4 2020, 06:51 PM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,960 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
Are there eight in the kit or six? They go on the long through case bolts, not the head studs:
![]() Attached image(s)
| TheCabinetmaker |
Feb 6 2020, 06:55 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,367 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
6 vibration dampers on case thru bolts. Have never seen windage tray rubbers in any of the 3 dozen kits I've used.
| Mark Henry |
Feb 6 2020, 09:50 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I've been using VR kits since the early 90's, nothing has changed.
RMS, nose seal or windage tray seals not included. |
Lo-Fi Version | Time is now: 14th March 2026 - 10:25 AM |
