FS: Speaker housing grill covers |
Pezz |
Feb 4 2020, 04:03 PM
Member Group: Members Posts: 63 Joined: 4-November 19 From: Paisley Oregon Member No.: 23,621 Region Association: Pacific Northwest |
Original Speaker housing grill covers from 1970
Left is pristine, Right has one broken screw hole and 3 broken grill bars, easily restored. Asking $90 OBO for both, Shipping included, Priority USPS Cashiers check or Paypal Please Thank you Attached thumbnail(s) |
jrblackbox |
Feb 4 2020, 04:30 PM
Member Group: Members Posts: 285 Joined: 8-September 15 From: Easton, CT Member No.: 19,140 Region Association: None |
Just a question? How are these easily restored? Thanks
Mike Fitton |
Feb 4 2020, 07:59 PM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
Pezz |
Feb 5 2020, 02:00 AM
Left is pristine, Lol! Looks Like the one you are calling the left side (2nd picture) also has a crack in the grill area, also the corner is broken off. Pristine? Thank you for pointing out the corner is broken. There is no crack. The plastic texture is causing a shadow in initial photo, and they still had moist spots after washing them. Maybe "Almost pristine"? Thanks Attached thumbnail(s) |
Pezz |
Feb 5 2020, 02:16 AM
Just a question? How are these easily restored? Thanks Perhaps I should not have said "easily." I considered making a wood or cardboard mold for the damaged areas and use an epoxy plastic putty and dremel. Could make repair pieces with a 3-D printer, or cutting pieces from another damaged grill. Not easy on time, but doable. Thanks |
Mike Fitton |
Feb 5 2020, 07:37 AM
Just a question? How are these easily restored? Thanks Perhaps I should not have said "easily." I considered making a wood or cardboard mold for the damaged areas and use an epoxy plastic putty and dremel. Could make repair pieces with a 3-D printer, or cutting pieces from another damaged grill. Not easy on time, but doable. Thanks Please proceed and post some after pictures! Be sure the grain in the wood mold matches the grain in the plastic. |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:58 AM |
