FS 19mm master cylinder 4 left NOT - the easy install, OEM style with rubber stoppers NEW unused |
Mikey914 |
Feb 10 2020, 01:57 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have 5 of these NEW in box just like OEM.
These are not the threaded easy install version. $88 each + shipping Attached thumbnail(s) |
stownsen914 |
Feb 10 2020, 07:51 AM
Which part isn't threaded?
76-914 |
Feb 10 2020, 09:13 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
not threaded where the two tubes insert on the top! (IMG:style_emoticons/default/beerchug.gif)
Tdskip |
Feb 10 2020, 11:01 AM
Oh boy - been through that on the 912. Air in garage still has blue tint several years later...maybe due to lack of skill on my part.
Mikey914 |
Feb 10 2020, 11:54 AM
NOT THESE is what I'm trying to emphasize.
Tdskip |
Feb 10 2020, 02:25 PM
Got this from Doug;
Remove the reservoir clamp and pull the lines down as far as possible from underneath. This gives you a little more access to install the lines. With the grommets installed on the supply lines I use a small screw driver and go around each rubber grommet pushing it down into the hole of the MC. I usually have to go around each grommet several times and do it in stages. Too much force and you can poke through the rubber grommet. Install isn't too bad. Its not fun but once you know how to do it, it can go pretty quick. |
a9146luvr |
Feb 10 2020, 10:55 PM
Member Group: Members Posts: 55 Joined: 2-January 04 Member No.: 1,495 Region Association: None |
PM'd
Mikey914 |
Feb 12 2020, 02:04 AM
4 left
Lo-Fi Version | Time is now: 6th June 2024 - 11:15 AM |
