| 914Sixer |
Feb 14 2020, 02:27 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,608 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
I thought I would see if the group had their thinking caps on. You only need this a couple of times. But the tool is very handy removing the part.
| bbrock |
Feb 14 2020, 02:29 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
Headlight switch removal?
| 914Sixer |
Feb 14 2020, 02:36 PM
You are close to correct. Escutcheon tool for removing all the dashboard nuts.
| rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
I've had this for years. No idea what it is or what it's for. (IMG:style_emoticons/default/confused24.gif)
Attached thumbnail(s) |
| 914Sixer |
Feb 14 2020, 02:43 PM
It's for removing pins out of later VW and Audi pin plugs . Might be handy to push female ends out of relay board harness plugs.
| bbrock |
Feb 14 2020, 03:05 PM
Your close to correct. Escutcheon tool for removing all the dashboard nuts. Ha! I'm claiming it. I just said headlight switch because that's the only one with a shaft that prevents a good ol' nickel or penny being used for removal. (IMG:style_emoticons/default/biggrin.gif) |
| 76-914 |
Feb 15 2020, 10:21 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,990 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
I made one by cutting a slice from a washer but not nearly as nice as this one. Now is the time for someone to make those available in a non-scratch plastic material. One of these whiz kids could print some, I'm sure. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 13th November 2026 - 09:37 AM |
