> Getting to Know You...., Geek'n Out on rocker cover removal and inspection
Craigers17
post Feb 15 2020, 04:32 PM
So this is the first decent day that I've had time to put the newly acquired '74 on jack stands and get to know her a little bit. I pulled off the rocker covers, and a tire and took some pics.
The worst rust I found was a brace on each rocker and a fairly massive hole under the driver's side seat/base of the firewall near the air deflector. All of this had been disclosed by the P.O.
Also, briefly scanned the underside and got the transaxle and engine numbers. By the way, one of the trailing arms clearly had a "K" stamped on it. Is that a Karmann stamp or does anyone know?
Replies(1 - 7)
Craigers17
post Feb 15 2020, 04:35 PM
Sorry about the upside down pics....need to work on that.
Craigers17
post Feb 15 2020, 04:37 PM
Craigers17
post Feb 15 2020, 04:40 PM
"K" on Trailing Arm
Spitball'n with some Minilites.
I'll add some more later when I figure out how to orient them all correctly.
Craigers17
post Feb 15 2020, 04:57 PM
Craigers17
post Feb 15 2020, 05:01 PM
Attached ImageAttached Image
Craigers17
post Feb 15 2020, 05:03 PM
Gave up.....no matter how I edit these, there's no rhyme or reason how they appear??
bkrantz
post Feb 15 2020, 08:52 PM
The jack tube cover flange looks different from original. You might want to investigate what is behind it.
- Lo-Fi Version Time is now: 3rd September 2025 - 03:44 AM
