No longer needed - LS conversion parts |
AG914 |
Feb 15 2020, 06:31 PM
Newbie Group: Members Posts: 1 Joined: 21-January 20 From: Michigan Member No.: 23,852 Region Association: None |
No longer needed
WTB: Adapter plate, flywheel, clutch, and pressure plate for LS swap. May be interested in the same parts for an SBC swap as well. Thanks! |
9144me2enjoy |
Feb 15 2020, 10:22 PM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
Looks like your fairly new to the forum, Welcome! You’ve probably done your homework on this conversion but if you haven’t you might want to check with Renegade Hybrid under 914 LS V8 kits. They have some pretty good options to get you started or complete your conversion. Depending on the Adapter plate you need for the transmission your going with, a beefed up 901 or 915 or 930 trans or a Porsche Boxster S 986 5 or 6 speed transmission along with stronger axles etc. or a Audi 6 speed trans..good luck with the build. You might want to start a thread under 914 World Garage for some knowledgeable forum members can help out which will save you a lot of time and probably a lot of $$!
Gearup |
May 18 2020, 10:00 AM
Member Group: Members Posts: 154 Joined: 21-April 15 From: Denver Member No.: 18,660 Region Association: None |
Lo-Fi Version | Time is now: 7th June 2024 - 05:59 PM |
