porsche 914 2.0 full set powdercoated engine tin, $800 porsche 914 2.0 full set powdercoated engine tin |
volkaholic |
Feb 16 2020, 07:21 PM
Newbie Group: Members Posts: 1 Joined: 31-July 15 From: Ohio Member No.: 19,015 Region Association: None |
$800 This is a real 1975-1976 Porsche 914 2 liter engine tin. It has the 3 bolt cylinder heads and the angled spark plugs that only came on this engine. CYLINDER TINS FIT THESE HEADS ONLY! The spark plug holes are in a different place than all other type iv heads! Top cylinder sheetmetal is specific for this engine!
This engine has all sheet metal to go into a Porsche 914, including the fan shroud + the firewall tin You get everything show, 25 parts + all new engine tins screws to install it all. All parts are OEM used German except the #3 cylinder surround which someone made, it fits, it works, i'm fine with it. SOME PEOPLE HAVE CLAIMED THIS IS NOT 914, WELL WHAT CAN I SAY, THE ENGINE CODE ON THE BLOCK IS 75-76 914, IT HAD FI, IT HAS 3 BOLT HEADS, IT HAS ANGLED SPARK PLUGS! now, is it possible that some one put 914 engine in a bus, a 411 or a 912, and then mixed in some other tins? yeah sure, so maybe some of the tin is different, but you got to have these cylinder tins for these heads. The following work has been done. good used, tested, german thermostat included new thermostat cable included fan included alternator included new fan belt included all engine tin blasted and powdercoated satin black cast fan shroud blasted and powdercoated agate gray - to match Porsche 356 fan shrouds price is $800 plus shipping, i use paypal Attached thumbnail(s) |
bdstone914 |
Feb 16 2020, 09:11 PM
bdstone914 Group: Members Posts: 4,529 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
That is not a complete tin set. Also the passenger top tin has been chopped for AC. Most of the pieces in the bottom row and the one in the upper right corner are not 914 parts.
You are missing the long two piece tin that goes under and in front of the fan housing. Warm air guides and one J tube are missing. |
914Sixer |
Feb 17 2020, 07:48 AM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Looks like 912E to me.
Nacho |
Feb 17 2020, 09:33 AM
Member Group: Members Posts: 219 Joined: 31-December 16 From: So. California Member No.: 20,716 Region Association: None |
That is not a complete tin set. Also the passenger top tin has been chopped for AC. Most of the pieces in the bottom row and the one in the upper right corner are not 914 parts. You are missing the long two piece tin that goes under and in front of the fan housing. Warm air guides and one J tube are missing. My guess was VW Bus or VW 411 -Nacho |
bdstone914 |
Feb 17 2020, 03:33 PM
@914Sixer post='2786630' date='Feb 17 2020, 07:48 AM']
Looks like 912E to me. [/quote] Some parts may be 912e Maybe. This is 912e tin. Attached thumbnail(s) |
Tdskip |
Feb 17 2020, 04:13 PM
I think this guy has a 912e engine that he's been trying to sell.
914Sixer |
Feb 17 2020, 06:21 PM
Bruce photo shows me wrong. So we know it is NOT 914 or 912E. Leaves only 411/412 or VW Bus
bdstone914 |
Feb 17 2020, 09:44 PM
@914Sixer date='Feb 17 2020, 06:21 PM' post='2786811']
Bruce photo shows me wrong. So we know it is NOT 914 or 912E. Leaves only 411/412 or VW Bus [/quote] I think it may be a mixture. The rear vertical tin is 914. The drivers top tin seems to have an extension I have not seen. |
Tdskip |
Feb 23 2020, 07:59 PM
This dirt bag is trying to sell these on Facebook and claimed there were no posts here raising issues.
Basically he is a scammer at this point. @ Eric_Shea - this guy should go. |
volkaholic |
Feb 24 2020, 01:50 PM
guys, the engine is a 914, i checked the number on the case, trust me, it is a 75-76 914, it had FI, it has the 3 bolt heads, only came on 2 liter 914, not bus, not 912, not 411,
volkaholic |
Feb 24 2020, 02:03 PM
there, i updated the ad, i think you guy are being a little critical
mepstein |
Feb 24 2020, 02:08 PM
914-6 GT in waiting Group: Members Posts: 19,305 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Lo-Fi Version | Time is now: 1st June 2024 - 06:36 AM |
