How to repair stripped transaxle half shaft flange CV bolt hole? |
tornik550 |
Feb 20 2020, 08:57 AM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have one hole on my transaxle half shaft flange that is stripped. I obviously need to repair this however I am not really sure how. I do not want to take apart the transaxle if possible. What are my options? Is it possible to replace the half shaft without taking apart the transaxle?
brant |
Feb 20 2020, 09:49 AM
914 Wizard Group: Members Posts: 11,628 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
yes.
buy a new transmission output shaft and a new seal pull the CV from that inboard side large headed bolt holds the flange into the tranny you won't have to remove the tranny it will be tight for space. I probably have a used -4 shaft and a seal (new) I could sell you brant |
dr914@autoatlanta.com |
Feb 20 2020, 10:00 AM
914 Guru Group: Members Posts: 7,875 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
not worth your time, used parts to replace are cheap cheap
I have one hole on my transaxle half shaft flange that is stripped. I obviously need to repair this however I am not really sure how. I do not want to take apart the transaxle if possible. What are my options? Is it possible to replace the half shaft without taking apart the transaxle? |
76-914 |
Feb 20 2020, 10:02 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
IIRC, that nut has a low torque value. This from a guy who can't remember what he had for breakfast this morning. (IMG:style_emoticons/default/laugh.gif)
Lo-Fi Version | Time is now: 28th May 2024 - 05:08 PM |
