Targa material question |
Thunderchief |
Feb 28 2020, 10:45 PM
Member Group: Members Posts: 146 Joined: 12-August 19 From: Pasadena, CA. Member No.: 23,365 Region Association: Southern California |
Besides the stock carpet like material, has anyone used a different type of material like vinyl or anything else?
71914-4 |
Feb 29 2020, 06:10 AM
Newbie Group: Members Posts: 21 Joined: 2-October 15 From: Central Texas Member No.: 19,226 Region Association: None |
I had my targa top sprayed with rhino liner both inside & out. Looks great.
76-914 |
Feb 29 2020, 08:18 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,512 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I've a burled aluminum dash panel and @MoveQik Mike Wills and a few others have replaced the back pad with Perlon
Mark Henry |
Feb 29 2020, 10:13 AM
The carpet cuts down on noise a little bit.
dr914@autoatlanta.com |
Feb 29 2020, 01:56 PM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
sure does, and it is easy and cheap to install and also keeps the matching and factory look. Vw did not put it in the early production cars, but found it a nice sound deadening improvement, so it was then standard in all 914s
The carpet cuts down on noise a little bit. |
Mikey914 |
Feb 29 2020, 08:25 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
You could try dynomat but probably overkill.
porschetub |
Feb 29 2020, 09:43 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
You could try dynomat but probably overkill. Could make your roof a bit more bit weighty Mark,a roof made like these will sweat ,the carpets there to stop that as they do on the inside of fiberglass boats and camper vans...I know a little about that (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 13th June 2024 - 06:27 AM |
