WTB '71 chassis wiring harness in good condition |
IronHillRestorations |
Mar 9 2020, 09:06 AM
I. I. R. C. Group: Members Posts: 6,728 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Looking for a nice '71 914-4 chassis harness. The harness in my customer's car is pretty hacked up.
T.Rick6 |
Mar 9 2020, 04:24 PM
Member Group: Members Posts: 51 Joined: 1-October 19 From: Douglasville, Ga Member No.: 23,512 Region Association: South East States |
I have a 914-612-021-10 that's in great shape, snorkel is not dry rotted, all rubber plugs still installed, no cuts, no corrosion, been stored for 20+years, willing to trade for -6 stuff or sale if the price is comparable to condition. Todd
JeffBowlsby |
Mar 9 2020, 05:25 PM
914 Wiring Harnesses Group: Members Posts: 8,532 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Perry, you need to be specific on the 1971 harness, there was a mid year change. Early has a 12 pin connector at the steering column, late has a 14 pin connector at the steering column.
Mar 9 2020, 06:05 PM
Good catch Jeff. Do you know what the VIN change was at?
mepstein |
Mar 9 2020, 06:46 PM
914-6 GT in waiting Group: Members Posts: 19,312 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
JeffBowlsby |
Mar 9 2020, 07:20 PM
Good catch Jeff. Do you know what the VIN change was at? I wish I did, have seen no indication of that in the manuals. Here is the DRAFT chassis harness ID guide. http://bowlsby.net/914/WiringHarnesses/914...nessIDGuide.pdf |
JeffBowlsby |
Mar 9 2020, 07:21 PM
Perry, you need to be specific on the 1971 harness, there was a mid year change. Early has a 12 pin connector at the steering column, late has a 14 pin connector at the steering column. That’s interesting. Was the late 71 different from a 72. '72 is completely different. See ID Guide above for specifics on each harness. |
Mar 9 2020, 08:08 PM
If you changed out the steering column cover and switches to the later style, couldn't an early car accept a later harness?
mepstein |
Mar 9 2020, 08:25 PM
JeffBowlsby |
Mar 9 2020, 10:14 PM
If you changed out the steering column cover and switches to the later style, couldn't an early car accept a later harness? Partially correct. Review each characteristic of the later harness being considered and see if you need to make any changes. A few examples in addition to the steering columm switches: Ignition switch type/connection Want the seat belt relay under the pass seat or the fasten seatbelt dash light? Early/late door switches were different Early/late headlight motors were different Dash gauge selection/wiring varies with the model year yada, yada... |
914_7T3 |
Mar 9 2020, 10:50 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
JeffBowlsby |
Mar 10 2020, 02:16 PM
AASE had several of these a couple of years ago and I had traded several correspondences with them. All they had at the time was the 1970-early 1971 with the 12 pin at the steering column. I suspect they misidentified this harness and indicate the wrong part number as a the later 1971 version. Anyone interested in this items should verify before buying. |
Mar 10 2020, 04:45 PM
Using a later harness will also require cutting out and changing the steering column bracket, which adds more to the mix of things required
raynekat |
Mar 10 2020, 07:23 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
I used the Aase harness in my 71 build and it fit perfectly from what I remember. Not cheap, but my harness was beyond help. Plus I wanted something very nice for the car. |
Lo-Fi Version | Time is now: 6th June 2024 - 08:01 AM |
