74' 2.0 shifting issue |
william1764 |
Mar 9 2020, 01:38 PM
Member Group: Members Posts: 252 Joined: 11-May 10 From: maryland Member No.: 11,717 Region Association: MidAtlantic Region |
Out of the blue she won't shift into 4th. Sounds/feels like I'm hitting up against something metallic which stops me from being able to enter 4th.
On a related note - any recommendations for indy in Maryland area? I live between Baltimore and Frederick. |
ndfrigi |
Mar 9 2020, 01:57 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
maybe your clutch tube that is welded to left side closer to shifter was remove and when you press your clutch pedal that tube will move towards the center/right.
william1764 |
Mar 9 2020, 02:17 PM
ndfrigi |
Mar 9 2020, 03:17 PM
maybe your clutch tube that is welded to left side closer to shifter was remove and when you press your clutch pedal that tube will move towards the center/right. Would that situation only impact one gear and not the others? try shifting it while engine is not running. can you shift it to 4th and 5th easily? or push the shifter all the way to right and press ur clutch pedal if you can feel something that is hitting ur shifter. |
Lo-Fi Version | Time is now: 11th June 2024 - 04:02 AM |
