Engine out, fixing oil cooler, 2.0 |
RolinkHaus |
Mar 15 2020, 07:34 PM
Member Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None |
RolinkHaus |
Mar 15 2020, 07:37 PM
thelogo |
Mar 15 2020, 09:20 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Superhawk996 |
Mar 16 2020, 06:21 PM
914 Guru Group: Members Posts: 5,885 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Looking good. So glad to see you digging into this and fixing those little issues that always pop up.
Great job! (IMG:style_emoticons/default/beerchug.gif) |
RolinkHaus |
Mar 17 2020, 03:49 AM
Best place to mount the cooler? Thinking under the trunk??
Also, anybody know the size of these fittings??? (IMG:style_emoticons/default/idea.gif) |
RolinkHaus |
Mar 17 2020, 04:16 AM
Upon re-installing the engine, is the engine compartment seal necessary? Would it not create a little more air flow, leaving it off?
Superhawk996 |
Mar 17 2020, 06:54 AM
Upon re-installing the engine, is the engine compartment seal necessary? Would it not create a little more air flow, leaving it off? No. Don't leave the seals off. You don't want airflow though the seals. The seals are there to help establish a separation between fan inlet (low pressure area) and the fan outlet above the cylinders (higer pressure area). This keeps cooling air moving in the proper direction. You want segregation between the cool air above the engine (inlet) and the hot air exiting below the engine. That hot is is then drawn out from under the car by airflow under the car when it's moving and the seals separate it when the car is stopped and idling. Hot air rises. At idle, without underbody airflow, and without engine compartment seals, the hot air will just rise up into the engine compartment and be recirculated. Worse yet, at idle it will actually be drawn upwards by the low pressure fan inlet and will be recirculated. Without seals you'll get a mixing of hot air from under the vehicle being drawn back into the engine compartment. This will IMPAIR cooling. Trust the Germans, they had this air cooling thing figured out. Alternatively - don't leave out the thermostat and the cooling flaps either. Those are needed too. Removing them leads to slower engine warm up and hotter running temperatures. The flaps act to direct air over the engine mounted oil cooler which it looks like you are keeping. |
RolinkHaus |
Mar 17 2020, 07:30 AM
Thanks for the information
Sea Rooster |
Mar 21 2020, 05:07 PM
Member Group: Members Posts: 106 Joined: 8-March 18 From: Nashville, TN Member No.: 21,948 Region Association: South East States |
Glad I found this post. My 2.0 is almost ready to go back in to the '73 and I'm having a hard time finding what seals go in the engine bay.
Car just got back from paint and I want new rubber. Does this package include what I need for the engine bay? ITEM # 914ERK 914 Early Rubber Package Manufacturer 914RUBBER Thanks! |
Lo-Fi Version | Time is now: 4th June 2024 - 03:51 PM |
