Transmission, 4 speed vs 5 speed |
Ampex351 |
Apr 8 2020, 10:11 PM
Member Group: Members Posts: 104 Joined: 8-April 20 From: Roseburg, Oregon Member No.: 24,115 Region Association: Pacific Northwest |
The '73 we just bought is a 4 speed. Any opinions? Good or bad?
Thanks! |
Krieger |
Apr 8 2020, 10:18 PM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
The 914 only came with a five speed. Your linkage may be out of adjustment or some of the bushings may be worn or broken.
Ampex351 |
Apr 8 2020, 10:51 PM
How many of you prefer 5 over 4 speeds? The car we bought is a 4 speed. Good, bad, ugly? I know that 5 speed was an option in the day correct?
bretth |
Apr 8 2020, 11:02 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
falcor75 |
Apr 8 2020, 11:35 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Its a dogleg gearbox, first is below reverse, chances are that you have mistaken second for first.....
Bmw635 |
Apr 8 2020, 11:50 PM
Member Group: Members Posts: 66 Joined: 19-February 20 From: OC, CA Member No.: 23,943 Region Association: Southern California |
Or miss counted reverse as it requires push down lockout before shift into gears.
porschetub |
Apr 9 2020, 12:37 AM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Never an option 5 speed only on a 4cyl car,cheers.
Mark Henry |
Apr 9 2020, 03:23 AM
914 were all 5 speeds, 60's 912 and 930 were 4 speeds. IIRC
Some V8 builders would leave 1st gear out, as it's a weak gear for drag race starts. Most big engines can easily start off from 2nd. When I first got a 914 I thought it was a 4 speed and wondered why it was such a dog in 1st (which was really 2nd) till I read the owners manual. |
billh1963 |
Apr 9 2020, 06:42 AM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
VaccaRabite |
Apr 9 2020, 07:26 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
How many of you prefer 5 over 4 speeds? The car we bought is a 4 speed. Good, bad, ugly? I know that 5 speed was an option in the day correct? By any chance is your car a v8 conversion? Many of those have been converted to 4 speed boxes. Stock they were all 5 speed. Zach |
Cairo94507 |
Apr 9 2020, 07:35 AM
Michael Group: Members Posts: 9,811 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Uh oh....... I hope the seller just assumed this car was a 4 speed and it was not something the seller told him. That would raise my suspicions about anything else they may have told him. I am hoping he actually laid hands and eyes on this car before making the purchase or at the minimum had a PPI by a knowledgeable 914 owner, etc. (IMG:style_emoticons/default/unsure.gif)
914e |
Apr 9 2020, 09:05 AM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
Sadly I need the pattern displayed on all my cars. The pattern is different in each one. Otherwise I'm in driveway hunting for reverse.
I think the PO of mine 914 just left it in second or third all the time There was switch to reverse. He didn't even think it still had a clutch. I was happy to find it still did. |
lierofox |
Apr 9 2020, 12:11 PM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
Yeah if the transmission is stock, 99.99% guaranteed it'll be a dog-leg 5 speed manual. Also... (IMG:style_emoticons/default/welcome.png)
Ampex351 |
Apr 9 2020, 03:25 PM
The green 2.0 we just bought is a 4 speed. Besides gear pattern and lower rpm's at higher speed is there any benefit to a 4 speed vs 5 speed? Just looking for opinions.
Thanks! |
mepstein |
Apr 9 2020, 03:36 PM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The green 2.0 we just bought is a 4 speed. Besides gear pattern and lower rpm's at higher speed is there any benefit to a 4 speed vs 5 speed? Just looking for opinions. Thanks! It's only 4 speed if someone left out first gear. No 914 was built that way from the factory. |
Chris914n6 |
Apr 9 2020, 03:53 PM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
As stated in your other thread, there was no 4 speed transmissions in 914s.
Your car either has a mis-aligned shift rod, worn shift rod bushings, or internal component failure. |
Craigers17 |
Apr 9 2020, 04:10 PM
Senior Member Group: Members Posts: 740 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
....maybe one of the previous owners swapped it with an older 911 or 912 4 speed tranny and put a 914 tailpiece on it..... I read about someone doing this in another thread here. That would account for the 4 speed.... I think the owner was told this was an original car, but the mirrors aren't....maybe the transmission isn't either?
mrholland2 |
Apr 9 2020, 04:11 PM
Senior Member Group: Members Posts: 750 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Weren't the Sportomatics 4 speed? (IMG:style_emoticons/default/poke.gif)
As stated in your other thread, there was no 4 speed transmissions in 914s. Your car either has a mis-aligned shift rod, worn shift rod bushings, or internal component failure. |
Ampex351 |
Apr 9 2020, 05:04 PM
Weren't the Sportomatics 4 speed? (IMG:style_emoticons/default/poke.gif) As stated in your other thread, there was no 4 speed transmissions in 914s. Your car either has a mis-aligned shift rod, worn shift rod bushings, or internal component failure. Thanks guys...I thought they were all 5 speeds but the damned salesman told me on the phone it was a 4 speed. I thought he was full of it. I appreciate your input. I'm told that all gears work fine except 5th (by another salesman) And it grinds going into 5th. |
billh1963 |
Apr 10 2020, 04:33 AM
Thanks guys...I thought they were all 5 speeds but the damned salesman told me on the phone it was a 4 speed. I thought he was full of it. I appreciate your input. I'm told that all gears work fine except 5th (by another salesman) And it grinds going into 5th. Have you actually laid eyes on the car? I'm afraid you are going to experience some disappointment if you are relying on a salesperson's description of the condition of the car. |
Lo-Fi Version | Time is now: 1st June 2024 - 08:32 PM |
