Seat belt Replacement 1976 2.0 |
dagersh |
Apr 15 2020, 04:16 PM
Newbie Group: Members Posts: 7 Joined: 4-April 17 From: Ancram, NY Member No.: 20,993 Region Association: None |
Hi Guys,
Trying to make the best out of sheltering in place by knocking out some long overdue issues with my '76. I pulled the seats today to attempt to CAREFULLY remove the rear upholstered cabin panel behind the seats to get to the belt retractors. I get that you need to pull the panel towards the front of the car at the bottom so that the retainers at the top can be cleared. First Question: How to remove the Engine Grill pull knob so that I can get the panel clear. I am assuming it is screwed on, but I want to confirm before I destroy it! Second Question: How are the retractors attached to the body of the car? Do I need to go in through the engine compartment? What little I could see from the passenger side, I did not see any attachment points. In the Engine bay on the driver side, I see some sort of attachment where it looks like the retractor would be located in the cabin. So there is where I am right now. I will have many more questions to come, as my cabin lights do not function right now, but the bulb is good according to my Multimeter. Thanks! Michael G |
dr914@autoatlanta.com |
Apr 15 2020, 04:39 PM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Just call me tomorrow and we can go over all of it on the phone
Hi Guys, Trying to make the best out of sheltering in place by knocking out some long overdue issues with my '76. I pulled the seats today to attempt to CAREFULLY remove the rear upholstered cabin panel behind the seats to get to the belt retractors. I get that you need to pull the panel towards the front of the car at the bottom so that the retainers at the top can be cleared. First Question: How to remove the Engine Grill pull knob so that I can get the panel clear. I am assuming it is screwed on, but I want to confirm before I destroy it! Second Question: How are the retractors attached to the body of the car? Do I need to go in through the engine compartment? What little I could see from the passenger side, I did not see any attachment points. In the Engine bay on the driver side, I see some sort of attachment where it looks like the retractor would be located in the cabin. So there is where I am right now. I will have many more questions to come, as my cabin lights do not function right now, but the bulb is good according to my Multimeter. Thanks! Michael G |
FlacaProductions |
Apr 15 2020, 04:51 PM
Senior Member Group: Members Posts: 1,616 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Engine Grill pull knob is threaded - pull it until you can get a pair of vice grips on the solid part of the cable right behind the knob - then you can unscrew it. Then you also need to unscrew the plastic part that is behind the knob - it's threaded in as well. Sometimes you can simply turn it with your fingers but you'll see two indents where you may be able to get the tips of needle nose pliers in there and get it started.
Retractors are bolted on from inside the cabin - you'll see them when you get the backpad off. The search function here is very powerful and there is a lot of info on seatbelts here. |
raynekat |
Apr 15 2020, 10:27 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Engine Grill pull knob is threaded - pull it until you can get a pair of vice grips on the solid part of the cable right behind the knob - then you can unscrew it. Then you also need to unscrew the plastic part that is behind the knob - it's threaded in as well. Sometimes you can simply turn it with your fingers but you'll see two indents where you may be able to get the tips of needle nose pliers in there and get it started. Retractors are bolted on from inside the cabin - you'll see them when you get the backpad off. The search function here is very powerful and there is a lot of info on seatbelts here. Flaca is dead on correct on all of the above. |
dagersh |
Apr 16 2020, 03:14 PM
Thanks guys. Flaca, I did a search, but was not able to come up with much. That said, i look forward to diving in.
FlacaProductions |
Apr 16 2020, 03:57 PM
What's the issue with your belts?
914 RZ-1 |
Apr 17 2020, 12:15 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
Thanks guys. Flaca, I did a search, but was not able to come up with much. That said, i look forward to diving in. For searching, I use Google as follows: type "914world.com: search criteria". No quotes, and type what you want to search for where it says search criteria into the Google search bar. For example 914world.com: seat belt mounting. That seems to work the best, definitely better than the search feature on this site. |
dagersh |
Apr 17 2020, 12:48 PM
What's the issue with your belts? Flaca, Age, brittle and driver side is really slow to retract. Plus, the new ones have a silver stripe! Should be good for 10hp and 1.7 seconds lap time on Lime Rock! (IMG:style_emoticons/default/drunk.gif) |
dagersh |
Apr 17 2020, 12:59 PM
Thanks guys. Flaca, I did a search, but was not able to come up with much. That said, i look forward to diving in. For searching, I use Google as follows: type "914world.com: search criteria". No quotes, and type what you want to search for where it says search criteria into the Google search bar. For example 914world.com: seat belt mounting. That seems to work the best, definitely better than the search feature on this site. RZ-1 I will try that. Thanks you. When the searches come up in a 53 page topic, its tough to go all the way through when I just want to work on the car. BTW - its the old MPC kit, but I like how it came out. MIchael Gershon Star Wars Modelling FB Page |
Lo-Fi Version | Time is now: 9th June 2024 - 02:56 AM |
