Bobby Smith |
Newbie ![]() Group: Members Posts: 28 Joined: 19-July 07 From: VA Beach VA Member No.: 7,926 ![]() |
Could one of the 914/6 experts tell me what makes the 914/6 Webers different than normal 3C Webers? Thanks.
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,262 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
I believe it is all in the linkage and connection to throttle rod.
Bobby Smith |
gms |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,718 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest ![]() ![]() |
I believe it is all in the linkage and connection to throttle rod. I'm thinking the 914/6 had Weber IDT TP13C The ID "T" being different. Would like to confirm that if it's correct. The IDTs have a different enrichment progression circuit than IDAs, better for smaller displacement. |
Bobby Smith |
I believe it is all in the linkage and connection to throttle rod. I'm thinking the 914/6 had Weber IDT TP13C The ID "T" being different. Would like to confirm that if it's correct. The IDTs have a different enrichment progression circuit than IDAs, better for smaller displacement. Yep, IDT came on 69T 2.0 and the IDTP13C was exclusive to the 914/6 2.0. |
E. Fry |
Newbie ![]() Group: Members Posts: 22 Joined: 3-April 03 From: Olympia, WA Member No.: 510 ![]() |
One throat draws fuel from one bowl and two throats from the other. I can't remember which is which, but the 916-6 Weber is opposite from the 911 weber.
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,822 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
IDTP, emission carb has a a Step on Mixture screw,, limiting fuel mixture on idlle ..
Show me an IDT |
DennisV |
Senior Member ![]() ![]() ![]() Group: Members Posts: 607 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California ![]() ![]() |
I believe it is all in the linkage and connection to throttle rod. I'm thinking the 914/6 had Weber IDT TP13C The ID "T" being different. Would like to confirm that if it's correct. It is possible that I'm confused, but I think it is the "1" that makes the 914-6 model number different: IDTP = 911 IDTP1 = 914-6 I have also been told by a well-know carb shop that: QUOTE The Webers themselves look identical from IDTP to IDTP1, the only real difference is the location of the main fuel jet installation. The main fuel jet location for the middle barrel is towards the front of the car so for 914/6 the location of the main fuel jet is relocated from that of the 911, nothing more that that and a part number difference. |
altitude411 |
I drove my 6 into a tree ![]() ![]() ![]() Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains ![]() ![]() |
delete
Lo-Fi Version | Time is now: 9th May 2025 - 12:10 PM |
