Are all distributor points plates created equal? |
saigon71 |
Apr 19 2020, 08:24 AM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I'm rebuilding the disty for a 73 2.0. The points plates are rusty and the ground strap is broken.
I've got a nice points plate in stock from a 1.7 and was considering using that one. Will this cause me any problems? Thanks! |
JeffBowlsby |
Apr 19 2020, 09:01 AM
914 Wiring Harnesses Group: Members Posts: 8,535 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Why not try to save this one? Soak it in apple cider vinegar to remove the rust, then give it a thin coat of oil.
IronHillRestorations |
Apr 19 2020, 09:06 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
They used to be available new. I had a couple NOS ones, let me check
914Sixer |
Apr 19 2020, 09:20 AM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
NLA for some time. Uses VW Type 311.905.227 points plate. NOT listed in the PET. Bosch 1 237 110 161 000 (152) This is how I repaired mine. AA has reproductions.
Attached image(s) |
bdstone914 |
Apr 19 2020, 10:37 AM
bdstone914 Group: Members Posts: 4,538 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@saigon71
' date='Apr 19 2020, 07:24 AM' post='2805928'] I'm rebuilding the disty for a 73 2.0. The points plates are rusty and the ground strap is broken. I've got a nice points plate in stock from a 1.7 and was considering using that one. Will this cause me any problems? Thanks! [/quote] I have many parts distributors and can pull a good one. As a back up clean tours,an resoldier the ground strap. I have one soaking now Bruce |
saigon71 |
Apr 19 2020, 07:00 PM
I cleaned up another set I had laying around and installed a new ground strap. Thank you for all the replies. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 11th June 2024 - 11:02 AM |
