Hell hole, Drain? |
Hell hole, Drain? |
fsh2liv |
Apr 22 2020, 10:21 PM
Newbie Group: Members Posts: 26 Joined: 22-November 13 From: Colorado Member No.: 16,687 Region Association: Rocky Mountains |
I was told by a fellow member of such. Does it exist? I can't find it. Mines a '73.
Thanks, Mark |
Literati914 |
Apr 22 2020, 10:41 PM
Senior Member Group: Members Posts: 1,476 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Look at the same area (well, feel rather than look) on the Left hand side of the engine bay..if it hasn't been replaced (that side usually doesn't need to be), then you'll notice a finger sized hole in the area you'd imagine it would drain from. Same hole should exist on the driver's side. IF someone hand formed and repaired the hell-hole area for a repair in the past, they may have mistakenly not included it. You need one tho, and could add it.
fsh2liv |
Apr 22 2020, 11:03 PM
Look at the same area (well, feel rather than look) on the Left hand side of the engine bay..if it hasn't been replaced (that side usually doesn't need to be), then you'll notice a finger sized hole in the area you'd imagine it would drain from. Same hole should exist on the driver's side. IF someone hand formed and repaired the hell-hole area for a repair in the past, they may have mistakenly not included it. You need one tho, and could add it. OK, I can't find it in my shop books, and the heater fan's in the way. Thank you I'll keep on. I need it as the "hole" is fine. Add it for sure. |
cary |
Apr 23 2020, 12:18 AM
Might still have a drain nipple in it.
rgalla9146 |
Apr 23 2020, 05:25 AM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Drain hole, drain nipple.....clogged.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 11th June 2024 - 03:16 AM |
