| gturner008 |
May 1 2020, 09:57 AM
Member ![]() ![]() Group: Members Posts: 127 Joined: 21-April 20 From: Toronto Member No.: 24,163 Region Association: Canada |
I know there’s been a few threads. But I’m stuck.
Bone stock 1976. I’ve checked the access panel in the front trunk. Only the fuel pump there. Checked rear engine bulkhead, and inside engine bay. Where am I not looking? Many thanks. Gary |
| cary |
May 1 2020, 10:05 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
How far did you pull out the pump ?
See if you can pull more hose on the left side. |
| gturner008 |
May 1 2020, 10:31 AM
I didn’t pull it out much at all. There didn’t seem to feel like there was much spare tubing.
Will the pump pull right out? It probably must be there. |
| 914Sixer |
May 1 2020, 11:37 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,509 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Should be in the holder on the wall directly behind fuel pump
| cary |
May 1 2020, 01:34 PM
Forgot I have a few chassis on site. Black hoses are going out the fuel pump mounting plate. Those fingers next to the steering column hold the filter. |
| gturner008 |
May 14 2020, 12:37 PM
So I found the filter - was behind the fuel pump.
I think it was the original, never changed. 40k miles over 44 years. It looked a bit gummed up. It’ll like running on a fresh filter! |
| ndfrigi |
May 14 2020, 01:14 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,983 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
So I found the filter - was behind the fuel pump. I think it was the original, never changed. 40k miles over 44 years. It looked a bit gummed up. It’ll like running on a fresh filter! You may want to replace your tunnel fuel lines including engine bay fuel lines to Stainless Steel. |
| gturner008 |
May 14 2020, 02:59 PM
I’ve checked them. All sound. No issues.
| Superhawk996 |
May 14 2020, 03:35 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,935 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Lo-Fi Version | Time is now: 5th July 2026 - 06:55 PM |
