Dash wiring help.. Red with white tracer power source? |
mb911 |
May 3 2020, 04:16 PM
914 Guru Group: Members Posts: 6,879 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Ok having a brain fart question.. I working through the wiring and have most figured out.. As of now I have no 12v power to the dash and the dash lights pop fuses.. What should I be looking for.. Black and blue. Tracer should be dash lights .. Any guidance would be appreciated.. Sometimes it just takes a little nudge.. And yes I have the wiring diagrams but having a moment..
mb911 |
May 3 2020, 07:02 PM
Can someone shed some light as to how the red and white wire gets 12v? I could easily jumper this but want to make sure I don't ruin something in the process.. This is just to power the gauges.. Thanks for any insight.
bbrock |
May 3 2020, 09:00 PM
Can someone shed some light as to how the red and white wire gets 12v? I could easily jumper this but want to make sure I don't ruin something in the process.. This is just to power the gauges.. Thanks for any insight. Red/white for the combo gauge comes off of fuse 9 (per 73 wiring). Edit: I should add that fuse 9 gets power from the black wire from the ignition switch so it is switched power. |
mb911 |
May 3 2020, 09:05 PM
Ok thats helpful.. Thanks..
Lo-Fi Version | Time is now: 6th June 2024 - 11:56 PM |
