porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,895 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
As per question,don't want to change oil because it pisses out the hole due to wrong tilt...thinking full extension on my bigger jackstands ??.
TIA. |
RickS |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None ![]() |
Get it up as high as possible. If you have some 2x6 pieces to put under your jackstands, use them too. Keep a couple of rags handy. One to plug the hole as fast as you can before much can drain out and one to clean the floor. You have to move fast.
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
2.7 qts is the quantity for complete refill, I've heard it can be done without loosing much, but have yet to see it. Love to see you show us how it's done. (IMG:style_emoticons/default/beer3.gif)
I've just resolved to change it. PS I sent out new seals to everyone so if you have the brown Viton one on the bushing change it out to the new black one as it will be easier to install. The Viton is harder making it more difficult. It was mailed in a manila envelope. |
framos914 |
Member ![]() ![]() Group: Members Posts: 125 Joined: 15-May 14 From: Corona California Member No.: 17,353 Region Association: Southern California ![]() ![]() |
Got the new seal in the mail but 2 days too late.
I did have a hard time installing the bushing with the brown seal. Might have to do it again since a small piece of the brown seal got sheared off. Lost just a small amount of oil, raised it high on passenger side and plugged the hole with a rag real fast. Make sure you have a pan or bucket underneath. |
Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,737 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
I’m thinking we have a new challenge here – let’s see who can change it with the least amount of oil lost!
infraredcalvin |
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,661 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California ![]() ![]() |
Ok dumb question and no pics cause I’m at the office. Yesterday I got the package. It came with the new shaft with o rings (2) installed. There was a small rubber gasket also included.... where does that go? I don’t recall this coming out when I swapped my last shaft...
porschetub |
Ok so its basically a no go then ,I will just drain it ,fitted the 914rubber replacement seal but it hasn't lasted long.
Might do the cable also as I have a new one (IMG:style_emoticons/default/beer.gif) . |
dax1969 |
Member ![]() ![]() Group: Members Posts: 388 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None ![]() ![]() |
Ok dumb question and no pics cause I’m at the office. Yesterday I got the package. It came with the new shaft with o rings (2) installed. There was a small rubber gasket also included.... where does that go? I don’t recall this coming out when I swapped my last shaft... Got mine yesterday as well.... understood the wrong brown seal is on but Mark promised to send me one. In my package there was no small rubber gasket ... can you post a pic pls ? Do I need it ? Why are packages different ? thks Dax ![]() |
Mikey914 |
That looks like black seal. the brown is really brown, and a distinctly different color. That would be why you only have the one. We corrected and just sent you what you need.
I'll post up pics today when I hit the shop |
infraredcalvin |
infraredcalvin |
SO.O.C914er |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,633 Joined: 18-July 16 From: Mission Viejo Ca Member No.: 20,199 Region Association: Southern California ![]() |
I have the brown one and still waiting to hear/see a replacement. My money is spent is sitting on my work bench. (IMG:style_emoticons/default/headbang.gif)
Mikey914 |
infraredcalvin |
Installed! No drama, will check for leaks in the next few days...
dax1969 |
You are correct that is the orientation. The seal we put out that we sent the replacement on id the one that we added. The thin one. Mikey, in my package there was no such rubber (IMG:style_emoticons/default/sad.gif) krgds Dax |
914e |
Member ![]() ![]() Group: Members Posts: 497 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region ![]() ![]() |
I’m thinking we have a new challenge here – let’s see who can change it with the least amount of oil lost! I was expecting to lose some but didn't lose any, because it was already over a quart low. I picked up gear oil last night to top it off. After I get it running again I plan on driving it around a few days then replacing the gear oil. |
porschetub |
You are correct that is the orientation. The seal we put out that we sent the replacement on id the one that we added. The thin one. Mikey, in my package there was no such rubber (IMG:style_emoticons/default/sad.gif) krgds Dax How common is it for the lip seal to fail ?..thinking that could be my issue (IMG:style_emoticons/default/idea.gif) . |
Mikey914 |
There is no lip seal in the OEM, so my answer is all of them have. It's a poor design, hence the additional seal we added.
porschetub |
There is no lip seal in the OEM, so my answer is all of them have. It's a poor design, hence the additional seal we added. Sorry but confused,not talking about O-rings but the small lip seal shown in the pic,are you saying that not fitted to the factory part and only to the one you sell?. (IMG:style_emoticons/default/beerchug.gif) . |
Mikey914 |
Sorry my misunderstanding when you said lip seal I assumed you meant the o ring on the bottom that sits just inside the lip.
The internal seal can leak, for the most part they aren't under any real pressure, so not a bad call to change out every 70-100k. |
Lo-Fi Version | Time is now: 31st July 2025 - 01:51 PM |
