> Name the wires #2
mb911
post May 5 2020, 07:10 PM
Please keep in mind I am not sure if the harness is a 73 or 74 model year or a little of both as the car clearly is.. These wires were cut when I got the car.. Any idea what they go to ? One looks like it should go to the gauge lights but not sure how that is possible way down by the brakes??Attached Image
Replies(1 - 17)
Nacho
post May 5 2020, 07:13 PM
What does the connector look like?
mb911
post May 5 2020, 07:30 PM
There are none.. It was clipped wire.
lierofox
post May 5 2020, 07:47 PM
Not sure on this one, black with blue stripe is usually dash illumination, but it's also used for the fog light switch along with a gray with red stripe wire. (Right parking light is also gray wire with red stripe)
Anyone know if the appearance group center console gauge lights get fed power from the wires going under the pedal board?
bbrock
post May 5 2020, 07:51 PM
QUOTE(lierofox @ May 5 2020, 07:47 PM) *
Nope. I'm pretty sure everything feeds into the center console from the firewall side of the harness except illumination lights.
This chump is stumped on these wires.
GregAmy
post May 5 2020, 08:16 PM
"Dionysius". A nice complementary name with little chance of confusion.
Craigers17
post May 5 2020, 11:31 PM
Center console oil temp gauge or volt meter?
https://www.google.com/url?sa=t&source=...CseC3gWsARsgQKg
EDIT: Sorry, I didn't fully read all posts above, ...color code is correct for these gauges, black/blue, white/brown, but if they are coming from the front of the car, then probably not.
IronHillRestorations
post May 6 2020, 07:39 AM
I. I. R. C.
If that’s gray/brown , it’s for the reverse lights
mb911
post May 6 2020, 07:41 AM
So the question is why is it up there?
buck toenges
post May 6 2020, 07:48 AM
Just curious, where is the picture taken? What part of the car is the wire cut off? In the tub by the tranny tunnel?
Buck
roblav1
post May 6 2020, 08:09 AM
Is the pic at the firewall?
mb911
post May 6 2020, 08:13 AM
Right by the pedal cluster
Dave_Darling
post May 6 2020, 10:36 PM
914 Idiot
What colors are the wires actually? I see dirt on them; is the one wire actually black/blue, or is it blue with dirt on it? Is the other wire white/red, white/brown, grey/red, or grey/brown? Checking the actual colors will let us narrow down our search on the wiring diagrams.
--DD
Costa05
post May 7 2020, 01:39 AM
If it is an AC car it could be to the compressor clutch on the engine with a return line to the Evap.
post May 7 2020, 07:50 AM
I. I. R. C.
Goes to the brake pedal switch
mb911
post May 7 2020, 07:57 AM
QUOTE(IronHillRestorations @ May 7 2020, 05:50 AM) *
Thats strange as well as the brake light switch wires seem untouched.
mb911
post May 9 2020, 09:04 AM
Ok back to this now..
The wire colors are grey and violet tracer and black with blue tracer.
Things that work to eliminate from this circuit
Front and rear running lights
Headlights
Gauges
Things that don't work
License plate lights
Rear trunk light
Gauge lights
I did realize that I have no door switches and don't think there is wire in the cavity..
So more thoughts
mb911
post May 10 2020, 01:40 PM
Found a short on the grey wire going to the firewall.. Still no connection to the license plate lights but made some progress..
- Lo-Fi Version Time is now: 7th December 2025 - 01:39 PM
