> AAR Voltage
solex
post May 9 2020, 11:01 AM
Hi All,
I'm debugging the hunting idle and just cleaned and validated the AAR is working properly on my bench.
When checking the voltage in the car I noticed then when the key is turned to the ON position I get a flash of voltage but it drops down to zero instantly and do not notice a constant 12 V when the engine is running. Is this the correct?
Thanks,
Dan
Replies(1 - 3)
Morrie
post May 9 2020, 11:16 AM
QUOTE(solex @ May 9 2020, 12:01 PM) *
Thanks,
Dan
Hi Dan,
My understanding is that the AAR is powered by the fuel pump relay. There would be a flash of power with the key on and engine off, as the fuel pump only runs for a few seconds with the engine not started to prime the system. Test again with the engine running and you should see 12V all the time at the valve.
GregAmy
post May 9 2020, 12:08 PM
Only on when the fuel pump is engaged.
solex
post May 10 2020, 01:59 PM
Thank you both, after cleaning it up, I confirmed that it works and is completely closed when the car has warmed up.
- Lo-Fi Version Time is now: 18th March 2026 - 07:42 AM
