Friday, 22 August 2025 |
SKL1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,723 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest ![]() ![]() |
Installing new front and rear main seals on my '73 2.0 (rear is flywheel seal) and haven't done this for a while...
Any new tricks to make installation either easier or successful? TIA. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Installing new front and rear main seals on my '73 2.0 (rear is flywheel seal) and haven't done this for a while... Any new tricks to make installation either easier or successful? TIA. I stub axle works well as an installation tool for the rear main seal with which it is the same diameter. There are two different depths if the rear seal. 10 and 12 mm. The seal rides on the curved part of the flywheel. I prefer to install to seal no deeper than is needed. It may not need to go to the bottom of the bore. |
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,568 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
There’s footage of installing the RMS in my clutch replacement video. Link in my signature below. Rear goes on pretty easy. For the front I use some permatex aviation sealant in the bore and a piece of pvc or large socket which is about the size of the seal. tapped on lightly. You can also just use a small wood block. Jake Raby uses a soft faced hammer directly on the seal in his rebuild video.
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
I have had the best luck having no leaks using the Sabo rear main seal. The orange colored seals seem to leak for me. (IMG:style_emoticons/default/mad.gif)
Regrease your flywheel needle bearing while you are in there and check the pilot shaft seal on the tranny. |
SKL1 |
Great videos! thx!
abes914 |
Member ![]() ![]() Group: Members Posts: 366 Joined: 30-March 11 From: Long Beach Member No.: 12,880 Region Association: Southern California ![]() ![]() |
any tricks on removing the old seals?
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,851 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
I have had the best luck having no leaks using the Sabo rear main seal. The orange colored seals seem to leak for me. (IMG:style_emoticons/default/mad.gif) Regrease your flywheel needle bearing while you are in there and check the pilot shaft seal on the tranny. +1 on Geoff's advice. Sabo is the only one to get. I got mine from Gowesty.com Here's a tech article they've got on type 4 rear main seals gowesty.com rear main seal article For removal I use a seal puller, but you've got to take care not to scratch the seal bore |
iankarr |
any tricks on removing the old seals? ...Also covered in the clutch install video (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 22nd August 2025 - 12:07 AM |
