> Fuel system question (3.2 / 3.6), Lets talk about that charcoal canister
RiqueMar
post May 12 2020, 10:39 AM
Enrique Allen Mar
For those of you that a running a 3.2/3.6 configuration or similar, do you still incorporate the stock charcoal canister?
I remember when the 3.6 was in the original car before purposed for my car, I would get a small oder and cannot remember if the canister was connected or not.
Replies(1 - 4)
Eric_Shea
post May 12 2020, 11:08 AM
PMB Performance
I always like to use them. It helps vent the fumes off the tank that create that old-car gassy smell and, there's usually plenty of places to add the fittings on the engine side. For 911 motors, we simply weld a tube on the plates coming off the fan shroud. That gives you the pressure needed to create the vacuum in the canister. Then you'll need to get the return line to vent into the intake before the MAF.
RiqueMar
post May 12 2020, 11:34 AM
Enrique Allen Mar
QUOTE(Eric_Shea @ May 12 2020, 10:08 AM) *
This makes a lot of sense. I don't remember if the black car had the canister connected, but I do remember on long-drives with the top on I would get a bit of fumes. The PO had, what I think was the tube to the intake plugged, so this may be easier than I think.
Edit: Any photos of this, or anyones setup, are greatly appreciated!
Gracias Señor Eric!
Eric_Shea
post May 12 2020, 11:37 AM
PMB Performance
Let me dig in...
Eric_Shea
post May 12 2020, 12:30 PM
PMB Performance
Bob’s vintage Sports Purpose air filters on PMO carbs. Base was modified to accept vent tube.
Kelly’s into more traditional watersheds on PMO EFI throttle bodies.
No pics of a Motronic system today.
- Lo-Fi Version Time is now: 11th July 2025 - 04:40 PM
