WTB/914-6 aluminum valve covers., Uppers and lowers OEM |
two914-6s |
May 14 2020, 06:36 AM
Member Group: Members Posts: 51 Joined: 1-September 14 From: Los Angeles Member No.: 17,846 Region Association: None |
I have an awesome 2.0 S spec engine in my original 914 six. Had it rebuilt a couple years ago and it's a joy to drive. But it's leaking oil and I'm going to have to rename it the SS Valdez. I have COVID-19 psychosis and I've been cleaning the underside of my car with a toothbrush. I'm looking for some new valve covers so it won't leak.
Thanks Dave |
gereed75 |
May 14 2020, 07:38 AM
Senior Member Group: Members Posts: 1,259 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
There are two fixes with your originals - mill them flat using a sheet of 120 sand paper taped down to a flat surface (granite counter top) and install them with squishy silicone gaskets
No leaky |
mepstein |
May 14 2020, 07:46 AM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The silicone gaskets take very little pressure. People usually overtighten.
xsurfer |
May 14 2020, 07:51 AM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
Are the existing valve covers milled to enable valve adjustment without lifting engine? If not have machine shop straighten
eric9144 |
May 14 2020, 08:22 AM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
I have COVID-19 psychosis and I've been cleaning the underside of my car with a toothbrush. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) It's cool Dave, lots of us have been there at some point, you're not alone (IMG:style_emoticons/default/beerchug.gif) |
roblav1 |
May 14 2020, 10:11 AM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
6 bolt lowers always leak. Mill them or do the flat sandpaper thing, which worked for mine.
Comment assumed a real 2.0 S engine. Regardless, use sandpaper. |
Retroracer |
May 14 2020, 10:54 AM
Senior Member Group: Members Posts: 616 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
Also responded to the OP post on FB, but to add in a few comments here:
- flatness is key; either turbo or original magnesium. Plate glass / sandpaper / grinding paste - whatever it takes. I was lucky enough to be able to pick from a selection of lower covers (the worst culprit for leaks) and select two that were almost perfect to begin with; which meant the minimum of material removed to get the sealing surface flat - turbo lowers will need to have some fins machined down for suspension clearance; maybe a bit more if you want check valve clearances with the engine in the car - the orange silicone gaskets were the last element of getting my covers leak free. Read the instructions that come with on torque settings, as if you get too aggressive they squish out and don't seal well also - nice car!! - Tony |
roblav1 |
May 14 2020, 04:25 PM
Coat each aluminum surface with Hylomar Blue. We use that on gasketless transaxles like Hewland MK series snd LD200. I used it all over my newly built 930 engine.
porschetub |
May 17 2020, 03:42 PM
Advanced Member Group: Members Posts: 4,705 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Coat each aluminum surface with Hylomar Blue. We use that on gasketless transaxles like Hewland MK series snd LD200. I used it all over my newly built 930 engine. (IMG:style_emoticons/default/agree.gif) great sealer,used to only use Loctite products till I got on to this years ago,gasket choice is important too. |
Lo-Fi Version | Time is now: 8th June 2024 - 05:50 AM |
