flywheel bolts, flywheel bolts |
02loftsmoor |
May 23 2020, 10:07 AM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
i think i know why, but why would some one grind off the heads of the flywheel bolts. and in this case i am. do you always replace the flywheel bolts on removal?? [attachmentid=745292
Attached thumbnail(s) |
914Sixer |
May 23 2020, 11:06 AM
914 Guru Group: Members Posts: 8,895 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Check the depth of your flywheel, guessing it has been cut wrong.
Mark Henry |
May 23 2020, 11:29 AM
Common
The bolt heads hit the old 4 spring discs if the fly is cut even once. The six spring 911 disc doesn't have this issue. Well... not as much, cut the flywheel too much and the 911 disk will hit as well. So cutting the bolt heads is still common. I've never had an issue cutting them down, I do it all the time, but I only cut off the ridge. |
02loftsmoor |
May 23 2020, 03:57 PM
02loftsmoor |
May 23 2020, 09:21 PM
Check the depth of your flywheel, guessing it has been cut wrong. any specks on flywheel depth ?? it's toast , but i have a fly wheel from a donor engine and a lightened flywheel Attached thumbnail(s) |
Lo-Fi Version | Time is now: 29th May 2024 - 01:03 AM |
