First post 1973 1.7, Vacuum troubles? |
Hawkiii |
May 23 2020, 06:57 PM
Newbie Group: Members Posts: 1 Joined: 23-February 20 From: Fairfield, CA Member No.: 23,959 Region Association: Central California |
Hi folks. I have been doing searches and just reading posts. Trying to learn as much as possible about these great little cars. I am trying to figure out why mine runs so crappy. The PO told me he rebuilt the engine and put in a mild cam and scrapped the FI and put on the dual Weber’s. From following you guys I am learning that vacuum is pretty important in these engines. I have a friend who was a master mechanic and he has explained many things for me and he stresses that vacuum is pretty important here. So I started checking into the vacuum lines and found I only have one. From one of the carburetors to the vacuum advance on the distributor. Is this correct? I have been trying to find a vacuum diagram for the 1.7 with dual carbs but all the ones I find detail the fuel injection set up. I set up my vacuum tester on the line from the carb to the distributor and started the engine. I could not register any vacuum at all. The needle just twitched at 0. Any help will be greatly appreciated. I feel like I am missing something with only one line. Thanks in advance for your help folks.
mepstein |
May 23 2020, 07:21 PM
914-6 GT in waiting Group: Members Posts: 19,300 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Frankvw |
May 24 2020, 10:36 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
I also have a 1973 1.7 , still working on it. With the help of 914world and its members I get a LOT of help if I need it. Since I still have the FI in place I cannot answer your question about carbs vs vacuumhoses, sorry ! |
914Sixer |
May 24 2020, 11:57 AM
914 Guru Group: Members Posts: 8,895 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Most people run VW 009 or rare 050 distributors. They are non vacuum units. Some one with carbs chime in
Lo-Fi Version | Time is now: 28th May 2024 - 11:21 PM |
