Battery, What is the recommended one? |
Ian Stott |
May 25 2020, 08:17 AM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
Probably need a new battery, have not been reading good things about the optima batteries compared to a few years ago. All responses appreciated.
Ian Stott Moncton Canada |
fiacra |
May 25 2020, 09:33 AM
Person.Woman.Man.Camera.TV Group: Members Posts: 332 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
http://www.914world.com/bbs2/index.php?act...=2&t=323517
An oft asked questions so I'm sure there are multiple other threads, but this is the one I remember. |
Mark Henry |
May 25 2020, 09:42 AM
Didn't I put an Odyssey 925 in your car?
IIRC I had to replace your Optima as it was cut through on one cell, because it wasn't bolted down. I know that was 4-5 years ago but It should still be good. (IMG:style_emoticons/default/confused24.gif) Did you let it go flat? |
FlacaProductions |
May 25 2020, 09:51 AM
Senior Member Group: Members Posts: 1,597 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Ian Stott |
May 25 2020, 10:20 AM
Didn't I put an Odyssey 925 in your car? IIRC I had to replace your Optima as it was cut through on one cell, because it wasn't bolted down. I know that was 4-5 years ago but It should still be good. (IMG:style_emoticons/default/confused24.gif) Did you let it go flat? Did not let it go flat, have trickle charger on when not driving the car much, like in the winter months! Ian |
Mark Henry |
May 25 2020, 10:28 AM
You should still be able to get a few more years out of it.
Is it cranking slower? This is about the best price on an Odyssey 925 in Canada, free fast shipping. https://saskbattery.com/ecommerce_155.htm Bolt in, you already have the posts on your old battery, and the bracket I made. |
Ian Stott |
May 25 2020, 10:54 AM
You should still be able to get a few more years out of it. Is it cranking slower? This is about the best price on an Odyssey 925 in Canada, free fast shipping. https://saskbattery.com/ecommerce_155.htm Bolt in, you already have the posts on your old battery, and the bracket I made. Thanks for the link Mark, if I need a new one I will get the same battery, since the bracket you made is in place. We have a Porsche mechanic in the Moncton area now, has experience working on 914s, he is an ASE and is from Belgium, teener is at his place right now, new rotors, pads, wipers are working again, spark plugs need changing, setting the valves,etc. He mentioned the battery seemed a bit weak, reason for my post. I am going to need a set of tires by the fall and I am noticing we have less to choose from for 15 inch tires. Was quite happy with the Bridgestone Potenza but no longer available. Ian |
Mark Henry |
May 25 2020, 11:09 AM
Or do you want a regular size battery?
I'll take the posts and bracket..... We need a "vulture circling" smiley (IMG:style_emoticons/default/laugh.gif) |
Mark Henry |
May 25 2020, 11:17 AM
....He mentioned the battery seemed a bit weak, reason for my post. Every Odyssey (and my old optima) I've had never showed much over 13 volts, where a lead/acid battery will show 13.5-13.8V. My old Optima after several years it only would charge to 12.5V but worked without fail till 10+ years. |
Ian Stott |
May 25 2020, 11:30 AM
Or do you want a regular size battery? I'll take the posts and bracket..... We need a "vulture circling" smiley (IMG:style_emoticons/default/laugh.gif) I will replace with the battery you linked me to, same as the one in the car now, reviews are all very positive and the bracket etc. you made is in already there. I will order the charger designed for the battery in the ad, I do not have that, may be the problem. Will see what happens after being on the charger the mechanic has. Ian |
Mark Henry |
May 25 2020, 11:54 AM
Or do you want a regular size battery? I'll take the posts and bracket..... We need a "vulture circling" smiley (IMG:style_emoticons/default/laugh.gif) I will replace with the battery you linked me to, same as the one in the car now, reviews are all very positive and the bracket etc. you made is in already there. I will order the charger designed for the battery in the ad, I do not have that, may be the problem. Will see what happens after being on the charger the mechanic has. Ian The literature that came with the Odyssey said if only storing 6 months don't charge, but do disconnect the battery. Just an FYI. (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 28th May 2024 - 06:06 PM |
